You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hey, sorry about that. I will re link them later today if I get a chance. For some reason I am not getting the notification of new post emails. In reference to the not being able to turn your wheels when stopped, worn ball joints can do it, bad alignment can do it among other things. Additionally, the valve in the hydroboost unit doesn't flow enough at idle, thats why it is hard to turn. If I roll just slightly I can turn fine. Guess I've gotten used to it. Larger tires don't help either...
__________________
2002 F-350 Powerstroke 4x4 Crew Long bed All black Lariat custom Cobra cb mount, 05 Mirrors, ZF6 mod, Manual Transfer Case
Camo,
Reps to you for even considering re-linking the pics.
I cut and pasted the whole post to MSWord and was attempting to plug in the pics from your Photbucket album but got confused and didn't want to botch it up. If you get the pics re-linked I'll make a PDF out of it. That is if you don't mind.
Hey, sorry it took so long. I am re linking the pictures up right now. I have been on the road and haven't been near internet for a bit. Links should work around 1hr from now!
__________________
I just got done replacing my powersteering pump on my 2002 7.3 and figured someone may benefit from pictures and a written how to...
Disclaimer: Ford-trucks and I are not responsible for anything which can result from mis installation or other issues that may arise from following this tutorial.
With that said, you will need a 1/2" drive torque wrench capable of 60 lb-ft, an 11/16" socket, a 3/8 to 1/2" drive socket adapter, a 7/16" socket with extension, a power steering pulley remover and installer kit, 1 qt Type F Ford transmission/power steering fluid, a 5/8" open end wrench, a new teflon seal for the high pressure line, a crescent wrench, adjustable wrench for removing clips, a flat bladed screwdriver, a drain pan with rags, and of course a motorcraft or equivalent power steering pump.
*Just as an update, Ford recommends replacing the pulley after being removed 2 times. Look for some sort of marking on the back and if there are 2, then replace the pulley. It is a friction fit.
First remove the air cleaner hose from the main housing using a flat bladed screwdriver. Set aside.
Then, loosen the 7/16" spring clamps for the intercooler boots, you do not need to remove them completely. Set the pipe aside. CAUTION: be careful when removing the intercooler pipe as the always hot feed to the alternator is near where you will be removing the pipe.
^Hot side for alternator. Watch out so the pipe doesn't hit back of alternator!
Put your 1/2" square drive in the tensioner adjuster hole, and loosen the belt off the powersteering pump pulley.
Next, use your adjustable wrench and remove the overflow hose by clamping down on the two tangs on the spring clamp. You will use the same procedure
on the lower feed line on the pump's bottom.
Now, remove the high pressure line from the pump, positioning your drain pan below pitman arm as fluid will start to drain out.
Since you broke the teflon seal while removing the high pressure line, install a new seal by either working the seal by hand slowly and carefully expanding it with your fingers, or by using the special Ford teflon seal installer. I worked it on by hand and have no problems.
You should now get your pulley puller ready to work. Following are pictures of how to remove the pulley...
It takes quite a few cranks to get the pulley assembly off, but make sure that you always have your hand under the pulley as if it fell, the pulley could get damaged.
Now remove the three main bolts holding the pump to the bracket. These are 11/16" bolts and are pretty snug.
Once those three bolts are taken out, you can remove the lower clamp and hose from the old pump, and transfer it all to the new pump.
Position the new pump where to old one was, making sure you put the return line, high pressure line, and drain hoses on. Tighten the three bolts back in. Ford spec was 60lb-ft for the three large bolts, however, mine were really snug at 45lb-ft. Take it as you please.
Now you can install the pulley. Make sure you drive it on straight. Using the tool, thread the inner bolt all the way into the pulley until it bottoms out, so you have as much threads in the shaft as possible. Now, just crank the installer down until it stops going. This will align the shaft perfectly flush with the pulley face.
You can now reapply tension and route the belt how it was originally. Fill the reservoir on the pump with your Type F fluid. Start the truck and apply the brakes while steering lock to lock, paying attention not to hold the wheel at lock for too long. Do this a few times, then shut the truck off. Check the fluid level and top off accordingly.
That should be it. Have fun!
__________________
One hour only took 17 minutes. Fast work and Thanks.
I have converted it into a pdf file for easy printing.
I have gone through 3 P/S pumps UGH!
I am running bigger tires, though
first one lasted about 85K miles(stock 265's) and the second one last about 60K miles(305's)
Hoping I get another 60-80K out of this one(315/70R17)
__________________ DP TUNED swamps single shots
02 F-350 lariat srw,supercab longbed 4x4 FX4 Transgo Tugger II, TRU-COOL 4739, AFE stage II intake, Bully Dog 5" turbo back exhaust Dieselsite coolant filter Rhino liner rocker panels
That's strange.....I'm in an almost identical truck with 228K on 285s since day one and am still on the same pump. Looks like my ticket is about to get punched though...
Was yours puking fluid or just getting loud when steering? Mine seems to be louder than it was last year. I haven't liked the steering on this truck since I bought it. I wonder if my pump is on its way out.
__________________
Jason
2000 F350 XLT PSD CC 6-sp SRW 4x4 - 6637
1986 F250 XLT Lariat supercab 4x4 6.9L IDI T-19, 4.10's
