Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-31-2008, 09:33 PM
willigiggin is starting off with a positive reputation.
460 with holley 4180C
I have a 34', 1989 Georgie Boy RV, the gas milege is awful 5 or less miles per gal.
Does anyone have a suggestion on modifications to the carburation system that might make a difference.
Is there anything to be gained in stripping all of the polution controls from this unit and replacing the carb.
I've tried with no success to tune the unit as it is but it's been like this
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-31-2008, 10:14 PM
Bear 45/70's Avatar
Bear 45/70 is gaining momentum as a positive member of FTE.Bear 45/70 is gaining momentum as a positive member of FTE.
Replace it with an different Holley. The 4180 is made by Holley to Ford specs and is an emissions carb and there isn't much you can do to it. I replaced the 4180 on my 1984 460, C-6 and 4.10 rearend in a F-250 crew cab, super duty (light 1 ton). Stock 6 to 7.5 mpg was the best I ever got. After the install of a Holley 1850S with a 2 stage power valve and reworked vacuum secondary spring, later opening. It added just over 1 mpg. I recurved the dist, to 35° mechanical advance in at 3500 rpm and with vacuum advance 50° total. The mpg is right at 10 mpg. The exhaust is both head pipes dump into a single 3" pipe, muffler and tail pipe. Other than going to headers it as good as it is gonna get.
__________________
Bear 45/70
Gimp Racing
  #3 (permalink)
Old 03-31-2008, 11:05 PM
Bern_F150_4x4 is starting off with a positive reputation.
Quote:
It's all about making as much torque as possible and then not using it . Might try advancing the cam if you have that nasty retarded chain...
__________________
'85 F150 4x4 300CID, NP435, 3.08's, Factory 15x8's, 31" Goodyears, Lock-Right in the back.
'86 F250 Supercab 4x4HD, 460 4V, T19, D50/Sterling 10.25 Trac-lok, 3.55's
FTE, yet another reason to have a networked PC in the garage!
The other side of green...
  #4 (permalink)
Old 04-02-2008, 02:11 AM
lewislynn is new and has a neutral reputation at this point.
I have a 88 Georgie Boy witht the same set up. I replaced the timing set-up, an RV cam and had higher gears put in the rear end and I increased my mileage 20%...It increased from 5 MPG to 6 MPG (that's a 20% increase)...But I drive it 65 + mph too.
  #5 (permalink)
Old 04-02-2008, 03:35 AM
Bear 45/70's Avatar
The best mileage tactic is to flat slow down. I quit the 60 - 65 mph stuff and now run about 55 and gained 1 mpg just from that even with 4 quads on a double axle trailer behind the truck.
__________________
Bear 45/70
Gimp Racing
  #6 (permalink)
Old 04-02-2008, 06:33 AM
Great stuff guys....I'm in snow country Canada so it's in storage right now but this gives me something to work with and I have some time to source out a carb. Bear do you know, is there much difference between an 1850s and the 4160 series Holley.
Yes I must say I push it pretty hard, not under 65 on a good highway, probably a good to slowdown even for safety.
  #7 (permalink)
Old 04-02-2008, 11:07 AM
Bear 45/70's Avatar
The 1850 is a 4160 carb. 4150, 4160, 4180 and 2300 are series of carbs. List numbes such as 1850 or 1850S are the actually numer of a carb. The difference between a 4150 and a 4160 is that the 4150 has a full size metering block, with regular jets while the 4160 uses a metering plate for jetting. The 4180 is an emissions modified, for Ford specifically, 4160 carb.
Here's a list of all Holley carbs by list number and the parts they use:
http://www.holley.com/data/TechServi...%20Listing.pdf
This page has much info need by by the Holleycarb use who is gonna work on it.
Holley Performance Products Technical Library
The whole site is very informative.
Holley Performance Carburetors, Fuel Injection, and Fuel Pumps
__________________
Bear 45/70
Gimp Racing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
