gt40 heads
Old 02-22-2002, 10:22 AM
evans's Avatar
evans
evans is offline
gt40 heads
I have been told that 289 HIPO exhaust manifolds will fit with no problem.
Mike/Ohio
Old 07-17-2002, 01:18 AM
beratte's Avatar
beratte
beratte is offline
gt40 heads
I know this is an old thread but I've been doing some research on the "P" heads and I found a company that makes the headers for the F-series 86-95. It's Central Coast Mustang [http://www.centralcoastmustang.com] They sell for $219. Hope this helps somebody.
Old 07-17-2002, 01:35 AM
kyle11's Avatar
kyle11
kyle11 is offline
gt40 heads
good to know. thanks for the update. Central Coast Mustang is in a lot of my Mustang magazines and seem to have fair prices on a lot of things. i'll check it out.
thanks again,
Kyle Dean
90 Bronco 5.0
Old 07-17-2002, 01:45 AM
TorqueKing's Avatar
TorqueKing
TorqueKing is offline
gt40 heads
Wow, I just realized how old this thread is. I installed the Windsor Jr's on my 302 with great success, the engine will consume no oil all the way to 3000 miles! The performance is great, and I couldn't be happier!
The TorqueKing
Old 07-17-2002, 01:49 AM
beratte's Avatar
beratte
beratte is offline
gt40 heads
TorqueKing, as the name implies, what kind of torque numbers do you think you are getting from your engine? I know you have the Winsor Jr's, what other mods have you done to your truck? I am debating swapping out my 302 in favor of a 351 (for the torque) or just build up the 302 with heads, intake, and exhaust. Mine's fuel injection though.
Old 07-17-2002, 01:50 AM
kyle11's Avatar
kyle11
kyle11 is offline
gt40 heads
I'll have to catch up on your threads, as I am leaning toward the Windsor Jr.'s myself. Sounds like less hassel and more performance from others I've solicited. Also looking into some of the CNC Powerheads, if anyone has any experience with this or similar....www.powerheads.com.
Old 08-01-2002, 12:18 AM
TorqueKing's Avatar
TorqueKing
gt40 heads
The motor:
Short Block: Recon Remanufactured, 302 bored .030", 9.7:1 static compression
World Windsor Jr. heads (1.94/1.60" valves)
Comp Xtreme Energy 250 cam (250/260, 210/218 @ .050", 110 LSA)
Crane Energizer Roller Rockers, 1.6 Ratio
Comp High Energy heat treated pushrods
Crane Blazer double roller timing set
MSD 6A ignition controls
MSD Blaster II coil
MSD Pro-Billet distributor w/vacuum advance
Weiand Action-Plus aluminum dual-plane intake
Spectre 4-hole aluminum 1" carb spacer
Edelbrock 600 cfm vacuum secondary carb
14" K&N open elament air cleaner
Flow-tech long tube, small primary headers
Copper/brass 4 core radiator
Permacool 16" HiPo electric cooling fan
Hydraulic lifter preload: .030"
cam is installed at 106 degree intake centerline (4 deg. advanced)
Timing set 36 degrees total, 14 initial.
It still runs on 87 octane detonation-free
Dyno 2000 reports: 330 HP @ 5500, 378 ft*lbs @ 3500.
Old 08-15-2002, 02:52 PM
brett_d's Avatar
brett_d
brett_d is offline
gt40 heads
Well to add alittle info for you all the plugs for the gt40p are autolight 103's. I have a set installed on my f250 and so far I have had no problems. I chose the gt40p's because of the cheap $500.00 cost for high performace heads (cant beat that!!!) and the fact that they are made by ford!
Old 08-16-2002, 07:45 PM
Ratsmoker's Avatar
Ratsmoker
Ratsmoker is offline
gt40 heads
You all need to visit powerheads.com and check out their CNC ported castings. Just a tad more than the GT40P heads but they out flow them by a bit on the intake and a mile on the exhaust. I'm going to put a set on my buddies 95 mustang next weekend. He was also looking at the GT40P heads until I showed hime these and ran both through the desktop dyno.
Old 08-17-2002, 03:30 AM
brett_d's Avatar
brett_d
brett_d is offline
gt40 heads
but what is the price tag on those?
Old 08-17-2002, 08:34 AM
jwtaylor's Avatar
jwtaylor
jwtaylor is offline
gt40 heads
Could someone enlighten me on this subject please? I as everyone else have noticed the price tag on these heads and thought how they would be the ticket. Keep in mind I have a 351 engine. Then I keep reading that special headers are required and then it hits me I am not paying $200 for a set of headers that in the long run if I decide to upgrade to a new head that they will not work. If you take in acount the $500 for the heads then $200 for the headers then you reach $700 which last time I checked you can get heads which outflow them theoretically for a $100 more. Again I am thinking in terms of using these on a 351 so if anyone has a new perspective on this please fill me in because my goal is only 400hp and these heads in stock form from what I have read should support this in stock form if not dropping off just shy of it. Any thoughts again please fill free to reply.
Old 08-17-2002, 04:00 PM
brett_d's Avatar
brett_d
brett_d is offline
gt40 heads
I used headman shorty headers on my truck with the original 5.0. When I swapped to the gt40p's I used the same headers without any problem! There was plenty of clearance from the boot and the plug!
  #28
Old 08-18-2002, 05:44 AM
kyle11's Avatar
kyle11
kyle11 is offline
gt40 heads
Powerheads are 695/pr. assembled. I believe that is with the core charge, however. IF....if the numbers don't lie, the flow better, but for my application (4x4), I have not decided if they are too radical (never would say that if it was for my mustang!). One thing on the powerheads is; there was little data available from them when I emailed them directly, and they had no cam suggestion upon request for the truck application (I've wrote them again, regarding all mentioned).
Windsor Jr. heads were reccommended to me, but it looks like World Castings has dropped cast iron heads for 302 completely (I've wrote them regarding).
A couple of questions on the GT40p's...you are the first one I know of to use these heads without getting custom headers, so I'm definitely interested. Assuming yours were new, were the chamber fairly smooth, or "as cast"? Also, I believe you mentioned you were using the shorty spark plugs...just want to make sure. One final question on them, what is the "thermactor passage" for? Jegs states these heads do not have this passage...don't know if thats the smog ports at the rear. If it is, I see a problem, as I have to keep mine legal.
The most important thing is, where do you find assembled GT40p heads for $500? Powerheads price is 695 assembled. I've not seen GT40p heads for less than than $550.
thank for past and future info!!!
http://www.worldcastings.com/
http://www.powerheads.com
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=4555&prmenbr=361
  #29
Old 08-18-2002, 08:17 AM
TorqueKing's Avatar
TorqueKing
gt40 heads
I know that World still makes iron heads for Ford, they make them in both Windsor Jr. as well as Roush 200 configuration. If they quit casting them, then Jeg's or Summit will still have them in stock for quite some time now. Price for either is $800 (pair).
'77 F100, 302 (the aftermarket Prodigy), C4
Cadet Second Lieutenant John F. Daly III
South Carolina Corps of Cadets, The Citadel
The TorqueKing
  #30
Old 08-18-2002, 03:59 PM
brett_d's Avatar
brett_d
brett_d is offline
gt40 heads
Everyone told me that I had to get special headers so I ordered them. For the heck of it I installed by old headers to see they would fit and they fit fine. The only problem was that I had to but the sparkplug socket on the plug and then turn it with an open ended wrench on some of the plugs. Not that hard and worth not paying the extra cash for the headers. I am not sure if the headman's that I had were just made different or what? I purchased the heads with a roller 350hp block from central coast mustang. They told me that the short block was $1500 and the long block with GT40P was $1995.00. Whether or not they sell the heads for 495 is a question you will have to call them about. The ports were quite smooth and there were no jagged edges.
What they are talking about with the "thermactor" is the crossover tube that runs from the back of the heads. I had Central Coast drill them and they did not charge me any thing with the purchase of the entire engine. The plugs were the same size as any other plug and the only difference was that the threads seated the plug farther into the head.
Quick Reply: gt40 heads
