Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Exhaust Systems
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-31-2008, 03:36 PM
turdbird is starting off with a positive reputation.
Exhaust making strange howling noise!!!!!
Ok, probably about 1/3 times i start my 96 f150 4.9 with true duals, the left pipe has a higher pitched howling noise, its a steady tone whether i rev the truck up or not it just gets louder. It will do it for about 6 seconds and then stop. The truck doesnt run badly because of it, but i took her to autozone to get her scanned and they said that the oxy sensor on the first manifold bank has a slow response on startup. Is that what causes this strange noise, i dont even know how it would make it, it sounds much different from the engine. The right pipe doesn't do anything. thanks.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-31-2008, 04:58 PM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
The slow response could indicate a bad sensor, but if you have an exhaust leak, it could be creating a howling noise if it was located in just the wrong spot.
More likely however, you should add an X-pipe to your system to balance out the exhaust flow. That seems to resolve most abnormal noises.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
  #3 (permalink)
Old 03-31-2008, 06:19 PM
I know that its not an exhaust leak, its almost electronic sounding. It started about 2 years after i put the duals on.
  #4 (permalink)
Old 03-31-2008, 06:56 PM
Sponsor
What kind of muffler do you have?
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
  #5 (permalink)
Old 03-31-2008, 07:34 PM
none, just walker high flow cats, its really strange, comparable to the howl of a wolf literally. It just isnt a natural engine noise, and the boys at the exhaust shop dont know what it is.
  #6 (permalink)
Old 03-31-2008, 07:46 PM
kens64 is starting off with a positive reputation.
Can you get a recording of the sound so we can hear it?
__________________
1964 F100- Gonna see boost
1998.5 Ford Contour- Many mods
JOIN THE NEW MEXICO CHAPTER HERE
  #7 (permalink)
Old 04-01-2008, 10:26 AM
Sponsor
Question, is there any chance the smog pump is still hooked up? I know your custom exhaust probably doesn't use the smog pump, but I suspect it could be possible that it could be involved. I don't know really, sounds like yours can be tough to pin down. My dad has a '92 E350 5.8L and when it is going between 35-45 mph under light acceleration, it develops a howling noise that sounds like someone blowing across the top of a bottle. We haven't isolated the source yet either.
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
  #8 (permalink)
Old 04-01-2008, 06:47 PM
i just have the air tube from the cat going out into fresh air, but this pipe specifically comes out of the front 3 cylinders, which the oxy sensor that is going bad is in the manifold of those cylinders.
  #9 (permalink)
Old 04-02-2008, 10:56 AM
Sponsor
See if plugging of that tube resolves the sound. Beyond that, I really don't know what to tell you. As I said, my dad's van makes a strange noise and we don't know where its coming from or what's causing it either.
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
  #10 (permalink)
Old 04-02-2008, 11:54 AM
xlman is starting off with a positive reputation.
definately plug the tubes on the cats. during decelleration vacume is created in the exhaust and any leak or open tube will draw fresh air in causing ignition of any unburnt exhaust. that gets things extreamly hot, especially in that area. that is where the dreaded " pop, bang, pop, bang" comes from when you let off the throttle.
__________________
1982 F150 Stepside - 400, 4spd/od,
1967 Mustang - 200, 3spd
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
