Hi I am working on my moms truck. When you turn on the truck everything is fine. WHen you turn on the AC, the AC compressor makes a clicking sound, followed by the engine shutting off. I took off the belts and the pulley moves fine. The compressor is about three years old. What should I do next?
I just removed the wires to the compressor and the heater worked but does not work when the connector wires are attached to the compressor. Also I checked the ac/heater fuse which is fine. Any suggestions?
