Bio Diesel, good or bad?
#31
#32
YOU DO NOT HAVE TO MODIFY A TRUCK TO RUN BIO!!!!! Unless your truck has rubber lines because it was built in the 80's.
Sorry, but I'm tired of the bad gouge going around...... you only modify the FUEL SYSTEM if you are running WVO. The actual engine never needs new injectors, this and that, or whatever else.
Check out the alternative fuel section for the proper gouge....
#33
Yep, Bio-b-good.
I started running B20 from the pump, and splash-blending on my own about 2 years ago...and it certainly helps my engine to run nice and smooth. The only time my engine gets noisy, is when I was really low on fuel and had to refuel with only the ULSD.
These days (exorbent fuel prices), I run a blend that is more in the range of B40-B50...splash-blending on my own.
As for sending as few $$'s as I can to the big oil companies...and most certainly not wanting to help Big Oil continue to generate record quarterly profits...I will continue to decrease my overall cost by blending my $3/gal Bio with the $3.89-$3.95 ULSD overpriced fuel that is available in my area.
...and my $3/gal...is going to a local brewer, who uses WVO to create the Bio that he makes available...and this is how he makes his living...so I don't mind the 50 cent jump in his price over the last year...and his brew is also not helping to contribute to higher food costs due to increased competition for feedstock.
In fact, with two girls in college and two boys in high school, I'd be remiss if I didn't use the Bio to lower my fuel expense, while also helping to improve our environment.
#35
So far my truck is running quieter, and it definitely smells different i'll have to wait and see if there's any change in mileage
#36
I just joined a co-op out here in norcal. it's $15 a year and they sell biodiesel from Pacific biodiesel at the cost they get it for (its at $3.99 a gallon right now) which is .20 cents cheaper than D2
I only care about it running quieter if it is meaningful. If it was noisy before because of the inadequate fuel system and the RR helps it, fine. If the RR hadn't changed the noise but gave it better fueling, I'd still go for it because I know that it is having a fuel starvation issue because of the way #8 gets shortchanged.
#37
I filled up with B20 for the first time last night. D2 runs about $4.199 around here (and thats a $0.20 drop over a weekend a half ago). i found B20 for $4.079 last night. Quieter, heck yes!. My wife and I could actually have a conversation standing at the front of the truck without raising our voices.
I'm sold.
I'm sold.
#39
The first few tanks of bio can make your fuel filter pretty dirty due to the fact that bio is a solvent and cleans out the system. However, not everyone has a lot of build up and residue in their fuel tank/lines. Before ULSD, it was pretty common to see bio quickly clock up a fuel filter as it cleaned the system out. Now with ULSD, that doesn't happen as much. ULSD is not as "dirty" as the LSD we had just a couple of years ago, so there's typically not as much buildup.
#40
#41
The Bio and Veggie oil has less BTU's than #2, so less power and usually less mileage. Possible gel problems in cold weather. I am using used oils (motor, hydraulic, transmission fluid, etc.) filtered very well and mixed with diesel. I also run the mixture through a processor to clean out undesirables. I have been doing this for a year and had great luck. Run 30 to 50% used oil to diesel. No loss in power, good lubrication, and no loss in mpg. I have a web page and a video about it if anyone is interested on our Archers-Friend.com site. Currently each gallon of oil I use saves me $4.50. All of my costs has been returned and I am making (saving) money now on fuel cost.
#42
I have run B20 exclusively for the past full year. Absolutely no issues at all.
even in winter when it got reasonably cold, I'd either add some Diesel Kleen or make sure I plugged up the truck. No issues.
I've posted this before, but I also see slightly lower EGTs with B20 over regular diesel. Not a huge difference, maybe 50* or so. But I watch pretty closely.
I enjoy it because of the lubricity benefits, readily available in my area, same price as regular D2, etc.
I change fuel filters about every 10- 15 K or so.
#43
I just started running bio this past week. The place here that sells is a 50 dollar membership a year. Its B70 and its 3.89 a gallon. I gotta say , i like how quiet my truck seems to be now. Kinda like the smell as well. Can't say if i really tell any difference in mileage or anything. Haven't been really running it long enough yet.
I also have noticed it seems that my EGT's seem to run a little lower with the bio diesel.
