Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 03-30-2008, 03:17 PM
kenpobuck's Avatar
kenpobuck kenpobuck is offline
Garage is empty, add now
kenpobuck is gaining momentum as a positive member of FTE.kenpobuck is gaining momentum as a positive member of FTE.
fuel lines
I am converting my 88 Bronco over to a 6.9 idi this summer and plan to make and run BD. My fuel lines right now are kinda cobbled and I am gonna rerun them and was wondering if aluminum is safe to use with BD? I ask only because I think I read on here about some metals reacting badly with BD. Thanks for the help.
__________________
DON'T BUY IT ..FAB IT!!!!
81 BRONCO 6.9 IDI, ARP headstuds, 3" dual straight pipes, isspro pyrometer, T18 4 Speed, 10.25 rear, d60 front, 4:10 gears, 37x12.5x16.5 wrangler m/t's (humvee takeoffs), 4" body lift. I am building the Bronco Ford should have!
Kentucky Chapter Member
  #2 (permalink)
Old 03-31-2008, 12:00 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
You better be carefull
I doubt that the Bronco's suspension can handle the weight of that diesel.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #3 (permalink)
Old 03-31-2008, 03:44 PM
kenpobuck's Avatar
I am swapping it all. Springs axles etc..
__________________
  #4 (permalink)
Old 04-03-2008, 03:20 AM
misnomer misnomer is offline
misnomer is starting off with a positive reputation.
As I recall in reading a report stainless steel was the least reactive metal and aluminum was next on the list then mild steel. Then ones they "report" as being reactive are copper and brass if I am remembering correctly. But that was mostly looking at VO and polymerization. With BD it is less of a concern, but you will want to replace your rubber lines with something else. viton hose works
__________________
1989 F250 4X4 SuperCab 7.3L NA (for now) 5sp 4.10 LS
1984 F250 4X4 SuperCab 6.9L ATS 093 Turbo T19 3.54
1985 F350 Flatbed 6.9L NA T19 (down)
  #5 (permalink)
Old 04-03-2008, 08:02 PM
kenpobuck's Avatar
Thanks, I knew about he rubber but was unsure of the metals.
__________________
  #6 (permalink)
Old 04-08-2008, 07:32 PM
stevilknevil's Avatar
stevilknevil stevilknevil is offline
stevilknevil is starting off with a positive reputation.
be sure you have plenty of filters on hand.that bio diesel shure scrubbes the crud out of a fuel system.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
