Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-30-2008, 02:41 PM
Passin Thru is starting off with a positive reputation.
Brazilian F 350
The Brazilian F 350 has a B 39 Cummins Turbocharged diesel in it. What an improvement over US 6 Liter diesels.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-30-2008, 08:36 PM
dzldude's Avatar
dzldude is starting off with a positive reputation.
wait, what a cummins.i gota see this
__________________
2008 F450 king ranch edition 6.4 PSD
2001 F250 platinum edition 7.3 PSD
1964 mack B-61
1986 F250 351 windsor
1986 F250 6.9 idi
  #3 (permalink)
Old 03-30-2008, 08:46 PM
SouthTexasDiesel is starting off with a positive reputation.
Pics? Where you see this?
__________________
08 F-350 Cowboy Edition 6.4 4x4 CC DRW 6-speed w/3.73 gears
Programmed with SCT LiveWire with DPF delete tune
Full 5" DPF & Cat delete pipe from Bay Area Diesel
6" Aussie stacks painted black
Random other goodies
  #4 (permalink)
Old 03-30-2008, 10:14 PM
JKBrad is starting off with a positive reputation.
Here's a link to the site. Hope you can read Portugese.
https://www.ford.com.br/sr_f250_default.asp?sr=f250cd
__________________
2008 F250 Lariat Crew Cab, 4x4, V10, Torqshift, 4.30 axles
http://www.ford-trucks.com/user_gall...&albumid=28250
  #5 (permalink)
Old 03-31-2008, 12:15 AM
randomhero1172 is gaining momentum as a positive member of FTE.randomhero1172 is gaining momentum as a positive member of FTE.
didnt work
__________________
- Joe
2002 f-250 CC long bed 7.3 PSD - 295,000mi: 6637, Zoodad, Foil Delete,Silverstar Ultras, CCV, 5" MKO Strait Pipe, Cab Lights, WW.
NEW!!!! - 1990 f-350 dually 7.3 IDI 12ft Alum. Boc. 197,000. A little shaky
  #6 (permalink)
Old 03-31-2008, 01:15 AM
gopedoligist's Avatar
gopedoligist is starting off with a positive reputation.
c'mon man i wanna see this!!
__________________
http://www.ford-trucks.com/forums/members/gopedoligist.html
keep it ford
  #7 (permalink)
Old 03-31-2008, 01:05 PM
rmosso1's Avatar
rmosso1 is starting off with a positive reputation.
Je ne parlais francais, and no spainish, but here is what was on he ad. Decipher someone?
Motor Eletrônico a Diesel O alto desempenho da nova F-250 4x4 tem nome: MaxPower. Desenvolvido pela Ford Brasil e pela Cummins, o motor foi projetado para o mercado brasileiro a fim de oferecer o máximo de performance com o mínimo de ruídos e emissões.
O motor diesel eletrônico MaxPower garante o desempenho que uma pick-up desse porte precisa, graças ao sistema common rail que oferece:
:: otimização da combustão, proporcionando melhor consumo de combustível e aumentando a potência e o torque;
:: atenuação dos picos de pressão na câmara de combustão, oferecendo maior silêncio e conforto;
__________________
2001 Excursion Ltd. V-10 (the GOOD)
2003 Excursion Ltd. 6.0 (the BAD)
2005 F-350 6.0, KR, long bed, 4x4 (the UGLY)
2008 F-350, 6.4, KR, long bed, 4x4 (LEAN, MEAN & BEAUTIFUL)
  #8 (permalink)
Old 03-31-2008, 01:10 PM
marcussen is starting off with a positive reputation.
Info from the website 3.9 liters Cummins (4 cylinder)
200 HP @ 2900rpm
Torque 369 ft/lbs @ 1500rpm
Electronic Common Rail injection
Looks like a 2003-2007 body style.
__________________
It takes hundreds of nuts to hold a truck together, but it takes only one of them to scatter it all over the highway.
DRILL HERE - DRILL NOW - PAY LESS
2008 F250, CC, Black, Lariat
Single Rear Wheels (4x2), Long bed,
Torqshift transmission, V-10 - 6.8L
4.10 Limited Slip
  #9 (permalink)
Old 03-31-2008, 05:07 PM
chairman13's Avatar
chairman13 is starting off with a positive reputation.
because it is a previous model...
  #10 (permalink)
Old 03-31-2008, 05:58 PM
rmosso1's Avatar
Living is learning! Who would think some developing country would be selling Fords, new, other than new 2008's or what I thought I was reading. Obviously they were advertising used trucks repowered. So glad to live in America.
__________________
  #11 (permalink)
Old 03-31-2008, 06:09 PM
chairman13's Avatar
the trucks aren't used. it is the 2003-2007(new;not used) model but with cummins engine...
  #12 (permalink)
Old 03-31-2008, 06:47 PM
rmosso1's Avatar
My only comment is then, I am glad they are only offered in Brazil. If I have a choice of a Cummins or no diesel in 2010 then I will buy NO FORD. I have had way too many problems with the Cummins problem engine offered. While Tom Hoffman experienced problems, my loss from the same block Cummins engine in marine application is exponentially more.
__________________
  #13 (permalink)
Old 04-01-2008, 01:38 PM
Maxium4x4's Avatar
Maxium4x4 is a name known to allMaxium4x4 is a name known to allMaxium4x4 is a name known to allMaxium4x4 is a name known to allMaxium4x4 is a name known to allMaxium4x4 is a name known to all
The Diesel Engine Electronic The high performance of the new F-250 4x4 has name: MaxPower. Developed by Ford Australia and the Cummins, the engine was designed for the Brazilian market in order to offer maximum performance with minimal noise and emissions.
The diesel engine electronic MaxPower guarantees the performance that a pick-up of this size needs, thanks to the common rail system that offers:
:: Optimization of combustion, providing better fuel consumption and increasing power and torque;
:: Attenuation of peak pressure in the combustion chamber, providing greater comfort and silence;
__________________
Read First FTE Guidelines
ULSD Click Here
2003 F-350 Reg Cab 6.0L-Custom Programming
424.59HP-669.67 Torque
  #14 (permalink)
Old 04-01-2008, 01:50 PM
Maxium4x4's Avatar
The link works now....
If the F-250 was the most requested at the time to pull anything and do the heavy work in the fields of Brazil, now with the 4X4 traction motor and the new electronic MaxPower of 203cv, it is unbeatable. Strong Breed More than ever.
With a new front, the new F-250 is even more impressive. The changes do not end there! Find out more by browsing menu.
Whether for work or for leisure, the new F-250 4X4 MaxPower is ready to face any ground and raise much dust.
The new F-250 4x4 is to design more robust and impressive. Now, the new model comes to roads with new grade and front bumper chrome, as XLT, and gray, as XL. The headlamps are more resistant to see-trough in the polycarbonate lens.
Moreover, the largest pick-up of Brazil was even greater. More high in the 4x4 versions, the F-250 is ready to go through any obstacle. We have the largest carrying capacity of the segment, both in the cabin simple, as in the double cabin. A new bucket with 8 feet, exclusive to the version cabin simple 4x4, which carries everything you imagine.
__________________
ULSD Click Here
  #15 (permalink)
Old 04-01-2008, 02:47 PM
GregsSD's Avatar
GregsSD is gaining momentum as a positive member of FTE.
I just want to get a set of those taillights for my truck!!!
https://www.ford.com.br/sr_f250_imag...mg=dsg_03g.jpg
__________________
2005 F-250 4X4 CC/SB 6.0 PSD, medium wedgewood blue
5" Procomp lift w/5"Donahoe rear springs
35x13.50 Procomp Extreme A/T's on Ultra Predator 18x10 wheels
Firestone Ride-Rite airbags
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
