Need Retaining Clip on shift Lever Arm
Hello folks. I replaced the bushing and insulator on my 3 spd column shift arms and the retainer clips that hold the linkage to the shift arm are worn and need replaced. I can't seem to find them anywhere. Does anybody know where to find them? I tried DC, NPD, NAPA, Autozone, LMC. My Detroit Iron CD doesn't show them so, I do not have a part number.
Any help would be appreciated. See my gallery for a pic.
Thanks
Gene
Thanks
Gene
Many years ago I lucked out by bringing the remaining pieces to the parts counter at an old-line Ford dealer, unfortunately those are few and far between these days
Numberdummy or one of the other Masters might chime in later with a part number, at that point someone like Green Sales ought to be able to fix you up
Try www.restorationspecialties.com and look at what they have, or try cross drilling the linkage and using a cottere pin instead of the clip you need. The mid-fifties linkage is cross drilled. Good luck!
371702-S .. Clip
This clip is wavy in shape, and is known as a spring clip.
The same clip was used from 1965 thru 1979 on cars and trucks.
EDIT: GREEN SALES has 10 of these clips (they are new old stock) available: 800-543-4959
Original types of reproduced FoMoCo hardware:
Check out dearbornclassics.com / online catalog / Pages 201 - 209.
You can order a free printed catalog: 800-252-7427.
Just wait'll you see all the goodies, there are other truck related parts in this catalog, too. Dearborn sells parts for Galaxies, other 1960's cars, but there's a pile of stuff that's truck related.
Cool....Thanks for the part number Bill.
Hey Bill.
I have a 65 f-100 with 3 speed on the column and 352 FE.
I need the pedal bushings and the bushings that go into the holes in the arms coming off of the steering column.
Thanks for the spring clip part number.
Sorry to hi jack your thread hgene226.
Oh yeah, I had to take the - out of 371702-S for Green Sales to find it on there web site.
Richard.
Richard.
Hey Bill. I have a 65 f-100 with 3 speed on the column and 352 FE.
:-) I LEAVE THE HYPHENS IN THE PART NUMBERS, BECAUSE MOST PPL JUST CALL GREEN SALES. (-:
Richard.
Richard.
Ford suggested retail price: $1.66 each / ftepartsguy.com price: $1.20 each
How are the two nylon bushings on the clutch rod that runs from the pedal to the equalizer (Z) bar? Those bushings wear out, that causes the 90 degree ends on that rod to crack, and sooner or later you'll be looking for a new one.
2) COAZ-7526-B .. Clutch Rod Bushings
Ford suggested retail price: $2.05 each / ftepartsguy.com price: $1.48 each.
There are two nylon bushings, two felt washers and two E clips on the equalizer bar. The bushings wear out, the clutch pivot ball studs go south, and soon you'll be lookin' for two of those, and they ain't EZ to find.
2) C1AA-7543-A .. Clutch Equalizer Bar Bushings / Retail price: $3.43 each / ftepartsguy.com: $2.47 each.
2) 358979-S .. Felt Washers / Retail price: $1.60 each / ftepartsguy.com: $.96 each.
2) 97474-S .. E Clip / Retail price: $1.80 each / ftepartsguy.com: $1.08 each.
C5TZ-7343-A .. Manual Control Selector Lever Bushing & Insulator Kit ~ On the column levers, under the hood-one kit takes care of both levers.
Fits: 1965/79 F100/350's with 3 speed S/T.
Retail Price: $16.32 / ftepartsguy.com price: $11.75.
All these parts are still available from Ford.
ftepartsguy.com is Ed Olson at Parr Ford, Bremerton WA.
When typing part numbers at Ed's site, or on Green Sales site, REMOVE the hyphens from the parts numbers!
BuckHammer
03-12-2016 09:44 PM
queen of spades
10-12-2013 03:45 PM
paulcalif
1997-2006 Expedition & Navigator
11-07-2005 10:27 AM
cashs66
07-14-2003 01:35 AM
