Burning a bit rich.
Burning a bit rich.
So I have a 88 EFI 302 with an AOD. I have no CEL and am pulling no codes but I am running rich. If you put your finger in the end of my tail pipe it will come out jet black. And at idle the smell of exhaust is very present outside the vehicle. I never really looked for the reasoning before but with gas prices the way they are it has me wanting to fix it. What are some things I should be looking at?
are the plugs covered in black, or do they look normal. what kind of MPG are you getting? have you advanced your timing (about 12 degrees) from the stock ten degrees beacuse of your agressive ignition module? If you (or a PO) advanced your timing too much or retarded it too much, it will run rich because of the incomplete fuel burn. Just my two cents.
You may be far ahead of me. When replacing the timing chain I noticed the pointer for setting the timing is not quite up to space shuttle quality control. It has sloppy holes and is just a light piece of metal that may not be accurate. My point is set your timing until you get just a little knock up long hills then back the timing off just a hair.
on
I have replaced the fuel pressure regulator twice just to make sure I did not get a bad one. My timing is advanced to 12. As for my plugs they are new as well and I am getting right around 9 mpg in town. To make a long story short I put a 302 H.O. in my truck a couple of years ago because I blew the original. Even before I blew the factory engine it was burning rich. So it kind of has me stumped.
I have not altered the computer or wiring harness. They both work with the H.O. The only real difference with the H.O. engine is that it has a roller cam and a 351 firing order. I used the original truck intakes. I have gone through and tested sensors and replaced everyone I could find. From EGR, O2, FPR, TPS, knock sensor, temp sensor, oil sensor, ignition module. The only ones I have not replaced is the IAC and MAP. I am getting proper vacuum from the MAP and also the right range from both.
Are you sure your injectors are also firing in the ho mode? Are you positive the
injectors are all opening and closing properly, Ie not leaking or letting some dribble out.
How old is the fuel in it? IF it is getting close to 90 days it is going bad and could be up
around 160 octane and that is why it seems rich because you ain't burning all the fuel
and you will never make any power like that.
kam, how frustrating. Just in case you have not seen what computers will fit...Ford Fuel Injection » EEC Program Codes
