Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 03-30-2008, 10:52 AM
STGFordCrazy04's Avatar
STGFordCrazy04 STGFordCrazy04 is offline
STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold
Useful Formulas and pointless numbers Youre welcome!
Engine Dispacement (Cubic inches)
Bore x Bore x Stroke x .7854 x Number of pistons = Displacement
460 stock bore is 4.362 and stock stroke is 3.85
4.362 x 4.362 x 3.85 x .7854 x 8 = 460.270 CI
460 .030 over = 4.362 + .030 = 4.392 bore
4.392 x 4.392 x 3.85 x .7854 x 8 = 466.623 CI
My personal favorite:
460 .030 over with 4.5" stroke
4.392 x 4.392 x 4.50 x .7854 x 8 = 545.403 CI
Here is a formula to tell you the optimum carburator size (CFM)
(Engine CID) x (Max RPM) X Volumetric Efficiency / 3456 = CFM
Volumetric Efficiency (VE) is a function of how well the engine can use the air that is pumped in it....basically.
For a stock engine use .75
For a mild engine use .80
For a modified engine use .85
For a race engine use .90-1.00+
(466) x (5500) x .85 / 3456 = 630 CFM Is the optimum amount of air than can flow into this engine at WOT under perfect conditions. I guess I dont really need a 750
Axle shaft torque load
(Torque) x (first gear ratio) x (axle ratio) x (90% efficiency).
Transmission 1st gear ratios
C6 = 2.46
AOD = 2.40
Np435 = 6.69
T18= 6.32
500 x 2.46 x 4.56 x .90 = 5047.92 Ft lbs of Torque.
This does not factor in tire size. Obviously tire size would effect axle load but anyway....
Here is what Mosers axles are rated at. (they are crap so dont buy them though)
30sp = 6200 ft lbs per axle
31sp = 7000 ft lbs
35sp = 9600 ft lbs
40sp = 12000ft lbs
U joint (size load and axle rating)
1310
Width 3.219" Cap dia 1.062" Max angle 30* Continuous ft lbs 130 Short term ft lbs 800
1330
Width 3.625" Cap dia 1.062" Max angle 20* Continuous ft lbs 150 Short term ft lbs 890
1350
Width 3.625" Cap dia 1.188 Max angle 20* Continuous ft lbs 210 Short term ft lbs 1230
1410
Width 4.188" Cap dia 1.188 Max angle 37* Continuous ft lbs 250 Short term ft lbs 1500
I want to do a front axle continuous and short term ft lbs rating but I couldnt find what I wanted. A while back someone on pirate built a machine to test the rotational "twist" break strength of several different axles and I couldnt find it. If anyone does please post it up.
Hope this helps.
__________________
Kris
Please do not PM me. My email is STGCountryboy312 at AOL dot COM
Quote:
Originally Posted by thorseshoeing
Yes you are the anti christ...
  #2 (permalink)
Old 03-30-2008, 10:55 AM
OverEngineer OverEngineer is offline
OverEngineer is starting off with a positive reputation.
nice math - Kudos!
__________________
F-250 XL 2001 6.8L V10 Reg Cab Long Bed "Ol'Ugly"
Lockers, Snorkle, Headers, Two Winches and a host of custom made goodies. Full details and photos in the gallery
http://www.ford-trucks.com/user_gall...?userid=455388
  #3 (permalink)
Old 03-30-2008, 10:58 AM
dragogt's Avatar
dragogt dragogt is offline
dragogt has a very good reputation on FTE. dragogt has a very good reputation on FTE. dragogt has a very good reputation on FTE. dragogt has a very good reputation on FTE.
nice, very nice.
__________________
92 Isuzu Rodeo 5sp 4x4
87 F150 lwb
83 bronco
86 mustang gt t-top
83 mustang gt
Aaron -STG's - Pirate Investigator
Quote:
Originally Posted by captain p4 View Post
If you can't tell if you have a body lift or not maybe you shouldn't be giving people advice in the offroad forum????
  #4 (permalink)
Old 03-30-2008, 02:54 PM
quadzjr's Avatar
quadzjr quadzjr is offline
just another Rockwell looser
quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE.
awsome calculator:
http://www.grimmjeeper.com/gears.html
i question that cfm calc......thats bs....
__________________
Nick
STG's Minions: Sergeant at Arms
The Rockwell/4-link/anything Badass Specialist!
Dont be a puss, RUN ROCKS!!!!
Quote:
Originally Posted by Ebay Assjack View Post
The truck was lifted with the custom frame as seen in pix. (the best way to lift a truck!!!)
My Build: 96' f150 4link 2.5 tons etc etc etc....
  #5 (permalink)
Old 03-30-2008, 03:06 PM
351slug's Avatar
351slug 351slug is offline
351slug is gaining momentum as a positive member of FTE.
I stand corrected, I just started looking alot down here last week and it seemed you ripped a new one in some of us newbs.But hey thats OK, we have to pay our dues. Thanks for the info. Whats your best time in the sand drags? My friend has a big block in a old bronco that sand drags and is getting beat by a 500+ CI dodge,DOT tire no paddles.
  #6 (permalink)
Old 03-30-2008, 03:27 PM
Quote:
.3 nanoseconds!
Are you in the right thread?
__________________
Kris
  #7 (permalink)
Old 03-30-2008, 03:36 PM
Quote:
Originally Posted by quadzjr
awsome calculator:
Thats a great link. I likey!
I got the CFM formula from 460ford.com Lets figure my 545 build
545x6200x.85/3456 = 831.06 cfm
I was told to use a 950HP on the small side and 1050 dommy on the large side.....maybe it isnt right. Scott wants me to use a 950HP with 750 venturis on my current engine. Hmmmmm.
__________________
Kris
  #8 (permalink)
Old 03-30-2008, 03:51 PM
351slug's Avatar
Quote:
Originally Posted by STGFordCrazy04
.3 nanoseconds!
I re read your post and you were mud racing 200 Ft. I think he is in 300 ft, really not sand, more like clay and dirt mixed dry beside the local mudbogg pit. Lots of street trucks and a few full modified. The carb formula seems on the small side or ive always had too big of carb.
  #9 (permalink)
Old 03-30-2008, 03:59 PM
monsterbaby's Avatar
monsterbaby monsterbaby is online now
monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation
most people over carb engines on the street all the time but on a race engine you run a lot more carb. I always try to tell people they don't need a 750 on a 460 but no one believes me for some reason.
also for those that don't know there is a section of automotive calculators on FTE.
http://www.ford-trucks.com/calculators/index.php
__________________
Rob
Dying's not so bad
It's living that will kill you off
  #10 (permalink)
Old 03-30-2008, 04:06 PM
oh ok. Not really the right thread for this but since you asked.
I cant remember my exact numbers but Im usually in the 4.5-4.7sec range in 200ft and always just under or right at 50mph of forward speed on an extremely similar track. My biggest hold up from keeping me competitive is weight. Many trucks in my class dip in to the high 3s on cut up trucks. They are technically supposed to be street legal (turn signals brake lights headlights insurance and tags) but it doesnt mean they are street driven or even could be. I drive my truck to work and hunting and if I could afford the gas Id drive it pretty much anywhere I wanted. I complain all the time about it but I cant run in the stock class because I have larger than 35" tires and Im running under the 5.0 sec cutoff. I dont do it for money...just fun.
Ive always heard everyone runs a carb that is really too big.
__________________
Kris
  #11 (permalink)
Old 03-30-2008, 04:22 PM
ibleedblue1385's Avatar
ibleedblue1385 ibleedblue1385 is offline
ibleedblue1385 has a very good reputation on FTE. ibleedblue1385 has a very good reputation on FTE. ibleedblue1385 has a very good reputation on FTE.
thanks for the information
__________________
-Jesse ~Built Not Bought~
1986 F150 4x4/5.0/SAS/5.13's
1988 F150 4x4
1978 Bronco
Michigan Chapter Member
  #12 (permalink)
Old 03-30-2008, 04:29 PM
351slug's Avatar
Thats a bad azz hunting truck.
  #13 (permalink)
Old 03-30-2008, 04:36 PM
There is always room for improvement.
__________________
Kris
  #14 (permalink)
Old 03-30-2008, 06:53 PM
bad96's Avatar
bad96 bad96 is offline
bad96 is starting off with a positive reputation.
another great writup Kris!!! ive read alot of your tech threads and appreciate them and the work you put into them for all of us!!!
thanks again for all the info!!!
  #15 (permalink)
Old 03-30-2008, 07:16 PM
Here is Bobby Longs (longfield axles) axle breaking machines results I robbed off pirate.
PRODUCT ................................ FT.LB. TORQUE / DEGREE TWIST
Yukon 4340 Dana 60 35 spline short side axle...12,000 / 130
Stock Dana 60 35 spline short side axle.........8,300 / 35
Yukon 4340 Dana 44 30 spline short side axle....5,800 / 35
Stock dana 44 30 spline.........................5,000 /35
__________________
Kris
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
