put a reciever hitch on my 05 f-150 4.2 reg cab auto. short bx 2 w. d.w/3.73 l.s.diff. going to tow 3000 lb. boat 25mi. flat ground .any recommendations for trans cooler or perfomance mods.also any body know what vibration dampener on r.r. of frame is intended to do.thanks in advance for any replies.
a ton and a half? flat ground? Your should be good, I have towed my car (5,000lbs with trailer) and I tow my dad's boat (2500 lbs) about 75 miles to and from the landing...
granted...mine is a stick..
__________________
91 Lariat Ext Cab S/B 4x4 302 auto (broke)
02 Sport Reg Cab 2x4 4.2 V6 5 spd (daily driver)
+1
You should be good to go.
If you happen to drive at a speed that has the transmission bouncing back and forth between locked and unlocked TC, or between in and out of OD, just push the "OD off" button and drive on.
Not sure about vibration damper.
Can you give more info on where it is located.
I'm curious now.
