Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-30-2008, 09:09 AM
deezel is starting off with a positive reputation.
towing
put a reciever hitch on my 05 f-150 4.2 reg cab auto. short bx 2 w. d.w/3.73 l.s.diff. going to tow 3000 lb. boat 25mi. flat ground .any recommendations for trans cooler or perfomance mods.also any body know what vibration dampener on r.r. of frame is intended to do.thanks in advance for any replies.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-11-2008, 11:41 AM
Jimmy Dean's Avatar
Jimmy Dean is starting off with a positive reputation.
a ton and a half? flat ground? Your should be good, I have towed my car (5,000lbs with trailer) and I tow my dad's boat (2500 lbs) about 75 miles to and from the landing...
granted...mine is a stick..
__________________
91 Lariat Ext Cab S/B 4x4 302 auto (broke)
02 Sport Reg Cab 2x4 4.2 V6 5 spd (daily driver)
  #3 (permalink)
Old 04-14-2008, 09:25 AM
BrianA's Avatar
BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.
+1
You should be good to go.
If you happen to drive at a speed that has the transmission bouncing back and forth between locked and unlocked TC, or between in and out of OD, just push the "OD off" button and drive on.
Not sure about vibration damper.
Can you give more info on where it is located.
I'm curious now.
Thanks.
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
Alabama Chapter Leader
  #4 (permalink)
Old 04-16-2008, 05:07 AM
on left side rear of frame.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
