Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-29-2008, 10:52 PM
TomThrall is starting off with a positive reputation.
bad factory door posts?
I just bought two new door posts. When I try to fit them to the new kick panels, I notice that the spot weld flanges on the front and rear of the door post are not in the same plane. IE, they are not square with one another.
Either the front lip will weld up, or the back but not both. This thing is like, 1/2" out of square. I have photos which show it better than I can explain it here.
But my question is, these door posts have to have square lips because they are welding to the kick panel, right?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-30-2008, 01:42 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
Do you have any way to post pictures? Might be easier to understand your problem.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #3 (permalink)
Old 03-30-2008, 03:21 PM
I figured out the problem. Actually, the parts are built right and i'm a ******* for not figuring out how the parts all fit together I took another long look at all the parts and discovered the kick panel is not flat and has an accomodation for this angle door post flange.
Is anyone here able to post pictures? I've been a member since 2002 but can't post pics...
I have some pics over at broncofix forum asking the same question
http://www.broncofix.com/viewtopic.php?t=273739
  #4 (permalink)
Old 03-30-2008, 04:23 PM
RCrawler's Avatar
Go to manage/ create your gallerie and create an album. Then you can download your pics. I think the max pixels is 3072, so you may have to resize them first. Once you have them downloaded, there is a prompt under the picture that lists forum codes for posting. I usually copy and paste that to my post.
Jason
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
