'66 F-100 Camper Special?
My Dad has had this truck socked away in the weeds for years, over beers yesterday we decided to find out if it is as rare as he's been told it is and/or what the Camper Special parts are worth.
It's not for sale at the moment, you guys will get a heads-up if that happens
F100 Camper Specials were made thru 1972.
F10 = F100 2WD
Y = 352 2V
C = Ontario, Canada Assembly Plant
874456 = 1966
129 = 129" Wheelbase
H = Sahara Beige (Exterior Color)
F100 = F100 2WD / 5,000 lbs. GVWR
C81: C = Medium Green Crush Vinyl & Medium Green Ladder Pattern Woven Plastic / 81 = 81B Custom Cab
G = MX Cruise-O-Matic
A8 = Spicer 44 Rear Axle / 3.54-1 / LIMITED SLIP / 3300 lb. Rear Axle Capacity
05000 = 5,000 lbs. GVWR (Gross Vehicle Weight Rating)
172 HP @ 4000 RPM
43 = Milwaukee, Wisconsin Ford District Sales Zone Office - Where the original selling dealer ordered the truck from.
Unfortunately, there's no data on any 1965/72 F100/250's Warranty Plate that ID's it as a Camper Special. Blame FoMoCo for that miscue.
NOTE: AS ORIGINAL: If a Camper Special, the R/L front fender emblem's RED plastic insert ID's it as such. If the insert says: Twin-I-Beam, it's not a Camper Special.
The RED plastic insert on your trucks chrome fender emblem on the drivers side appears to be missing.
See the next post v v v v for info on the Camper Special Package.
Thanks
Any info is helpful
The main reason if found its way back in the pasture is that the front cab supports were rusting out, it had a case of the usual midwestern rust
It certainly isn't improving any with the passage of time
The Camper Special badge is still in place on the passenger side, the drivers side badge curled up and fell out when Dad lit my old Chevy next to it on fire one spring while burning off weeds
It's at the point where he needs to find a more solid body-donor or give in and part it out, I expect discussions to continue for a while
Any info is helpful...
They were optional on all other Custom Cabs and the Ranger.
This truck should be saved, there wasn't a lot of Camper Specials made originally, so there's very few left today.
I don't like to burst any hopes you may have, but here is my perspective as just a truck lover.
Your truck is not rare. Not a dime a dozen for sure, but not rare. It is even possible to add the CS features to a regular truck, and you wouldn't know it didn't come from the factory that way.
It is in terrible shape, and is rusting out. The hood is no good due to the nose rot. The grill is dented and the bed is rusting out with the trash in it. The cab mounts and the floor pans are replaceable, but at significant expense and time.
Anything soft inside is gone, including the dash pad.
About the only value it has is the original hard trim and bezels inside, but they were used in larger Ford trucks into the early '90s, so even they are not rare.
You might get some dollars for the dash gauges and the door trim around the inside, perhaps up to $100.
If the tailgate is not rusted through AT ALL - NO PIN HOLES you might get something for it, maybe $100.
Restoring that truck will take in excess of $25K, not counting labor. That amount assumes all labor is done by the restorer.
Restored, the truck might be worth 10K. Maybe. And, only to someone who wants exactly what has been done to it.
Let it sleep in peace.
Originally Posted by rusbukt
I'm a softy for an old Ford truck in the field on the farm. It needs to stay right where it is.
It has done its time. Now let it rest.
Lets all raise a beer to the ol-timer.
The only thing wrong with that picture is the burned out hulk next to it! That thing needs to get buried.
Dad mentioned today that it really did'nt owe him much
However it works out the old girl will be providing some parts for something more solid, there's no point in letting it rust into the ground.....
Enough snow has melted I'm *finally* back at work on a Hauler, that burned out hulk and some other 'treasures' are going to provide me with some pocket money in a few weeks
I am in agreement on a couple points... it is what I consider a rare truck...its what appears to be straight as an arrow except the front bumper...grilles for 66 are being repopped now, as are the underpinnings of the cab...mounts and floorpans...The hood can be fixed...many would toss it, but I think its high time these hoods, rusted up front or not...unless grossly rotted or beat be saved as they arent being repopped.
I have seen very very few 1/2 ton CS trucks which in itself makes it rare. If it does get parted, buzz me, Im more then happy to save an old warrior or at least parts of it...door panels and fenders as well as the t/gate and core support.
- cs65
Stay tuned for more pics added to the gallery...
- cs65
- cs65
- cs65
Originally Posted by billy12360
hey man... i already called dibs on the tail gate... ehh thats fine... it looks different then my 63 but i dont know what a 63 tail gate looks like since mine dosent have one from the factory[it has a home made tail gate for a 5th wheel]
Jeff
