1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
headers
Old 03-16-2008, 10:30 AM
schmitty65's Avatar
schmitty65
schmitty65 is offline
Question headers
i have a 65 f100 2wd with a 351m and c6 also have installed powersteering but am having trouble figuring out what headers will work and get past steering box and clear crossmember any help is appreciated
Old 03-16-2008, 11:10 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
Pro-Street/StateTK is offline
Schmitty
Welcome to (FTE)!
You will need to buy your headers for 73-79 the frames on these trucks are
the same up front! I have not install any headers on the 351m/400 ! But you
search some of the old posts you should turn up a lot. When you search
keep in mind you will be looking for info on headers for 65-66,67-72,73-79, so
you may want to check out posts in those forums also!
P.s. heres a link to my gallery take a look at the crossmember that I modded.
https://www.ford-trucks.com/user_gal...=79912&width=2
Wally Womack
Old 03-16-2008, 11:46 AM
rusbukt's Avatar
rusbukt
rusbukt is offline
Was curious as to which steering box you have? Bendix or Saginaw?
I am running a Bendix and had to tweek one of the pipe's a bit to get it to clear the box.
I know it is no-no to "dent" the header. But at the time.??
Old 03-17-2008, 12:35 AM
Pro-Street/StateTK
Rusbukt
I really dont think theres nothing wrong with having to dimple one of the tubes, as long as you use the side of a big socket and tap it easy a little at
a time, the headers will still flow very good.
P.S. now on a set of headers that are ( TUNED ) I would really try not to
dent them, if you dont need to!
Wally Womack
Old 04-12-2008, 07:36 AM
heavy d460's Avatar
heavy d460
heavy d460 is offline
I have a 61 merc on a 63 frame (unibody). I was having the same issues with headers and steering. I have a 460/c6 combo in the truck.
What I found that worked best is a set of hooker headers from 88-94, they fit very tight to the engine, and the drivers side runs almost under the tranny. I did not have to heat and bend any thing, and there is all kinds of room.
Hope this helps a little, don't be scared too try headers from other years of trucks, all demensions and measurement are available on line for most quality headers
Old 04-12-2008, 10:39 AM
daveengelson's Avatar
daveengelson
daveengelson is offline
Don't believe you will be able to install headers w/ a Bendix box. If recall, Sanderson Headers will make to fit.
Sanderson Headers - Custom Built Headers
Have a 390 in one of my 65's with Hedman long tubes, and another 65 with a 302 and using Hooker long tubes. Only issue was on passenger side crossmember, had to remove minimal amount of material to increase flange clearance. Also, had to lift engine slightly, and if recall, remove starter to install. Used Hedman offset extentions to get around the tranny crossmember issue. Intend going with Pro-Streets model when I replace mufflers, which should be soon, way too loud.
Old 04-12-2008, 10:54 PM
billy12360's Avatar
billy12360
billy12360 is offline
i was hoping you had the y-block in your truck... i was going to say reds headers..i ordered a set from them... and the drivers side clears everything...
the only problem i had with the company was... the fact that they sent me to driver sides... i called them up and they are sending me a new one back...
Amphihauler
01-31-2017 03:06 PM
The Masked Rider
26
02-06-2013 08:10 PM
veedogtoo
12-19-2012 07:39 PM
Melmo65
17
12-06-2012 01:57 PM
Quick Reply: headers
