Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-29-2008, 06:56 PM
jazzcat is starting off with a positive reputation.
2001 E150: Tie Rod End reattaching?
Howdy Folks,
I'm trying to reattach the tie rod ends after replacing the balljoints on my wife's 2001 E150.
How in the world do I prevent the ball joint attaching bolt from turning as I tighten it? I'm on step 24 in the URL noted below. If I use a crowfoot and grab on to the threads with pliers, then I risk damaging the threads, and I can't use a torque wrench that way.
http://www.ford-trucks.com/article/i...line_Vans.html
Thanks!
-JC
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-29-2008, 07:30 PM
mhg mhg is offline
mhg is starting off with a positive reputation.
take a small amount of steel wool
and insert into the hole
then use a C-clamp to press the 2 parts together
you should now have enough bite to torque it down
__________________
2003 bull 3.0 24v stock
1996 E-350 351
  #3 (permalink)
Old 03-31-2008, 05:41 PM
Clubwagon is starting off with a positive reputation.
Most technicians use a big prybar to force the tie rod or ball joint down into the socket. That provides enough load to tighten the nut.
__________________
Steve
'95 Clubwagon XLT
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
