Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-29-2008, 05:36 PM
corys46 is starting off with a positive reputation.
Red face Coolant on piston 97 F150 4.6L
OK,where do I start The motor misses,does not show on live codes. new plugs,Then found coolant on some pistons.Can this be the Intake gasket?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-29-2008, 06:55 PM
Question Compression
BTW tested compression,wet It's up and down;80-120 took a few tries for #7 to show a reading suspect a sticky valve.
I actually stuck a rag into the c-chamber and it came up with coolant on it.
Also,smell of combustion in the coolant tank and coolant smell out the exhaust
Oil was a bit brown,so I changed it
Going to try pressurizing the coolant.
286000kms on the beast(129000mi) My next move is Gunk block sealer,then a used motor,before I get too much into this one.
Any advice would be appreciated.
  #3 (permalink)
Old 03-30-2008, 12:43 AM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Welcome to the forum
Sounds like either a blown head gasket or cracked head to me.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #4 (permalink)
Old 03-30-2008, 07:15 AM
Thank you
I've heard some rumor about intake gasket problems.
How do I test for that?
I've got an air ratchet and I'm not afraid to use it!
  #5 (permalink)
Old 03-30-2008, 06:07 PM
LxMan1's Avatar
Pressure testing the cooling system should help pinpoint the leak. Usually if it is an intake problem, it will leak in the front, not near cyl 7.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #6 (permalink)
Old 03-30-2008, 08:41 PM
Coolant in #1
I found the most coolant in #1
So far,I've drained the coolant and filled with water twice,running the engine each time until t-stat opened.removed the lower hose and flushed thoroughly.Coolant is still coming out brown.
There is a lot of sediment in this system. Also when the initial problem occurred,Green coolant was added,about 5 months ago,then the truck sat for a while...
With the rad cap off,the motor didn't seem to miss as much.
I pulled off the 3/8" line from the top of the coolant tank and stuck it under the coolant level through the rad cap hole;it bubbled steady with the motor running.Is this from combustion gas?
It will overflow the coolant if I leave the cap off long enough with the motor running
  #7 (permalink)
Old 03-31-2008, 12:17 AM
LxMan1's Avatar
Sounds like a head gasket.
you need to put the cylinder up on top dead center so that both valves are closed and put compressed air into the cylinder ( I use a compression tester hose with the shrader valve insert removed) and see if you get bubbling in your coolant overflow. If so, the heads need to come off.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #8 (permalink)
Old 03-31-2008, 07:29 PM
Mr mom
Thanks I'll give it a try.Playing Mr mom tonight!
  #9 (permalink)
Old 04-08-2008, 05:46 PM
Gunk
I've been running Gunk and water in the rad for a week now.Seems to have stopped leaking
Also found a cam follower had come off,when I opened the rocker cover found about 1/2" of sludge under it.flushed the crankase with a quart of diesel,then dropped the oil.(only abot 80 miles on it)Came out real black
Now my oil pressure guage stopped fluctuating too,must have loosened up the crap in that sensor too.
Thanks again LX MAN1 You've been a great help!
  #10 (permalink)
Old 04-08-2008, 10:25 PM
LxMan1's Avatar
Good luck
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #11 (permalink)
Old 04-30-2008, 01:47 PM
Ladyfire3374 is starting off with a positive reputation.
LX,
I have a 4.6, 160k mi, had an overheat incident due to leaky radiator & inexperienced driver. Replaced radiator & t-stat, (fresh coolant but no flush), coolant still leaking, temp still heads into the hot zone on warmer days.
I travel for work now & don't do as much of my own work as I used to. :-(
My mechanic says he did a "block test" and found exhaust in the coolant, which is very dark and smells somewhat of exhaust.
It was hesitating a lot til it warmed up, but I took off the reservoir cap and let the coolant bubble back into the reservoir (glub, glub). The hesitation hasn't happened since. Later that day, I also added some stop-leak.
Is this definitively a cracked head/block/blown gasket or is it worth my time to look for an intake gasket leak?
  #12 (permalink)
Old 05-01-2008, 10:39 AM
krewat's Avatar
krewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud of
Sounds like combustion pressure is getting back into the cooling system - bad head gasket, cracked head, cracked cylinder, etc.
BUT - one thing to look out for, is the plastic intake might have cracked internally and is pushing coolant into the cylinder. But by now, it's probably hydrolocked anyway.
Pressure check the system.
__________________
- art k. - Moderator for the Superduty, V10, and FE-series forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 eBay headers and y-pipe
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 4x4 435NP 205NP deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #13 (permalink)
Old 05-04-2008, 07:22 PM
Krewat,
Thanks for the timely reply.
Two questions:
What is hydrolocking?
How do I do a pressure test? Do I need to compression test to find the suspect area, then do as LX recommends below or are you thinking of something else?
  #14 (permalink)
Old 05-05-2008, 07:45 AM
krewat's Avatar
Hydrolocking is where you get water (or some other fluid) in the cylinder, and on it's compression stroke, can't compress the liquid, so it cracks the piston, spins a rod bearing, etc. Not good.
Pressure checking the system means pressurizing the cooling system and seeing if the pressure drops, meaning there's a leak.
A compression check is where you check compression in every cylinder, if one or two are low, the head gasket is most likely leaking.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
