Can a Bosst valve be installed with E4Od in truck?
The accumulator boddy? I've been in there just the accumulators and line presure modulator. no boost valve. http://www.sonnax.com/part_summary.p...3&make=2&unit= in the pick in this link it looks like it goes in the pump. the guy at the trans shop I bought the stuff in assured me it could be changed with the trans in the truck but?
Thanks for the respones TJ
George:
I am the fartherest thing from a tranny tech but just surfing through the Sonnax site that you provided it clearly shows that the boost valve goes into the: "Pump Body" after low pressure leak down tests are preformed.
Hopefully one of the tranny guru's will jump in, C00nhunter,Madvan,TJ,the rest of you???
Rog
Rog
It takes a while for revers to engage and soft shifts. I'm just replacing it with some other parts in the valve body to firm up the shifts a bit. I replaced the line presure modulator and the accumlulator springs I'm happy with how it turned out so far. the only thing I'm not 100% happy with is the 2/3 shift is a little softer than the 1/2 shift I might change some thins around in there tomarow.
