Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 03-28-2008, 08:44 PM
LostMayhem LostMayhem is offline
Garage is empty, add now
LostMayhem is starting off with a positive reputation.
2002 lightning engine sound
I just turned my truck on and im getting a wierd clicking sound. I think i had the oil changed 3,000 miles ago, do you think its time to change it again? Does anyone know what the cause of this sound could be because it doesnt sound good.
  #2 (permalink)
Old 03-29-2008, 02:11 AM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
1999 Ford F-250
My Garage
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Is it a faint clicking sound you can only hear with the hood open? If so, it's most likely your injectors.
However, if it's not faint, and you can hear it clearly with the hood closed, especially if it sounds a little like an exhaust leak when you step away from the truck, you need to check you plugs NOW.
Do not drive it until you have removed the COP's and using a socket (plug removal socket) check each and every plug for tightness.
Make sure no plugs are loose, because they make a ticking sound just before they launch.
Tighten them down to 12 - 13 foot pounds of torque.
Stewart
__________________
The Brotherhood of FTE <-click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff
2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes
Never Fry Bacon NAKED!
  #3 (permalink)
Old 03-30-2008, 12:03 PM
jakdad's Avatar
jakdad jakdad is offline
jakdad is starting off with a positive reputation.
Sounds like a loose plug.
  #4 (permalink)
Old 03-30-2008, 01:43 PM
There was a faint ticking sound for the last week, and when i turned my truck on yesterday it became much louder. If the plug launched Can i drive to a garaged or should i get towed? What are COP's?
  #5 (permalink)
Old 03-30-2008, 04:18 PM
Stewart_H's Avatar
1999 Ford F-250
My Garage
Quote:
The ignition system on Gen 2 L's is a Coil Over Plug system (aka COP). You have one for ever plug, and they look like this.
Click the image to open in full size.
Remove your coil over plug and check each spark plug to make sure they are tight.
The heads on the Ford modular engines (pre-2003) are notorious for launching plugs.
If the plug launches, yes, you can drive it to a garage.
When mine launched a plug a few year back, I was going to unplug the injector and drive it 8 hours south of me to have an insert put in. The only reason I didn't was because the extreme, obnoxious exhaust noise would have been way too much for me to handle for an 8 hour trip.
Stewart
__________________
  #6 (permalink)
Old 03-31-2008, 01:32 AM
Thanks alot Stewart.
Tags
2001, 2003ford, 46, coilover, engine, f150lightning, ford, good, lightnin, lightning, modular, plug, soud, sound, test, torque, truck, values
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
