2002 Navigator air suspension sagging rear - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 03-28-2008, 08:52 PM
ejjones55 ejjones55 is offline
ejjones55 is starting off with a positive reputation.
My '02 Navigator just started sagging in rear. I know this is common problem with the air ride. Here is something weird, I am currently selling the SUV and let a guy test drive it for about 15-20 mins. I was not in the Navi with him. He brought it back. I got in it today and realized it was riding funny. CK Susp light went on. I checked the switch under glove box, it was on. I turned it on and off. I don't think the pump is even turned on, I don't hear it.
I don't think the guy did anything to it, but it just was weird!
I am hoping a fuse????
Any help...
Old 03-29-2008, 10:51 AM
Update, I drove it around today and could hear the pump kick on, but the rear is still low and now moving at all.
Old 03-29-2008, 07:11 PM
lsrx101 lsrx101 is offline
lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.
Your Navi is a little young to for the rear springs to have worn out but stranger things have happened. If the compressor is running and the rear won't raise, there's a pretty good leak somewhere.
Did you ever notice it dropping when parked overnight?
Leaks in the air springs are, by far, the most common problem. Have someone put it on a lift and let the axle hang. Look closely at the springs for cracks, tears, or other damage. If all looks good, check all of the air line connections with soapy water with the compressor running. (Kids bubble liquid in a spray bottle works great for this). Make sure the lines are all connected.
If it is below freezing outside, moisture in the dryer could have frozen and is blocking airflow, but this would indicate other issues with the system too. The vent valve in the compressor could also be stuck open.
Old 03-30-2008, 09:26 PM
Mark62's Avatar
Mark62 Mark62 is offline
Mark62 is starting off with a positive reputation.
What about my 99?
The compressor runs forever.
Old 03-31-2008, 07:07 PM
Quote:
Originally Posted by Mark62 View Post
What about my 99?
You are at about the end of the life expectancy on the rear air springs. Get it checked out quickly. The compressor is not intended to "run forever" and will very quickly wear out, adding $$$ to the repair.
Old 03-31-2008, 09:16 PM
Jugger Jugger is offline
Jugger is starting off with a positive reputation.
my compressor had starting turning on more frequently than usual so i looked at my lines. i found one cut in two.
Old 03-31-2008, 11:51 PM
Quote:
That is very possible, but it's also very uncommon. That's why an initial visual inspection is important before intense troubleshooting. Spring failures are the most common failure, but anything "can" happen. Don't jump to conclusions.
Old 04-02-2008, 11:27 PM
Mark62's Avatar
Where do I get the air springs?
2 places I have found:
New rear air spring assembly. for 1997-2002 (4 wheel drive) Expedition
Suncore Industries - Ford Expedition Air Suspension Parts and Conversion Kits
for the 44.00 difference I would rather get the "lifetime warranty" set.
Old 04-03-2008, 12:08 AM
You could try the Dealer. They're about $250 each. They are the original Firestone air springs that lasted ~10 years.
For aftermarket. I would recommend Arnott for quality, only because I'm not familiar with Suncore. I have Arnott parts in service that are 7 years old with 0 failures.
Rememer, "The price of quality parts is forgotten long after the warranty runs out". Buy the cheaper ones, but plan on replacing them again while you own the truck.
Old 04-04-2008, 11:34 PM
Mark62's Avatar
I bought the Arnott springs because of the lifetime warranty,
and yes my expy starts dropping as soon as I turn the key off...
Old 04-11-2011, 07:34 PM
yankee1911 yankee1911 is offline
yankee1911 is starting off with a positive reputation.
Navigator air supension
I just repaired the air supension on my 2002 navigator. the problem was the compresor relay located under the compresor. (Lay on your back and look up behind the front passenger side light.) $102 from ford dealer. CAUTION: the trobleshooting tip. "Does the car lower when turned off?" is not the best indicator of a problem. This is normal in the navigator for ease of entrance. Chech the owners manual.
Old 07-13-2011, 10:32 PM
Josh888 Josh888 is offline
Josh888 is starting off with a positive reputation.
I have a 2000 Navigator 4WD. The rear end dropped just out of the blue and the air suspension motor does not come on. I ran power directly to the air suspension motor and it runs fine, So I replaced the Module and the motor still does not come on. I replaced the rear hight sensor and still nothing. I jumped the motor to run it and aired the rear end back up. But I cant get the motor to come on. There is and has been a slow leak in the air line so the air suspension motor used to run everyday twice when i would start it for about 30 seconds. Any ideas why the motor will not come on? I checked all of the fuses. They are good
Old 07-13-2011, 10:52 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
You replaced the air suspension module or the pump relay?
Old 03-03-2016, 05:45 PM
bbad bbad is offline
bbad is starting off with a positive reputation.
Quote:
were you just not getting power to the pump
Old 03-04-2016, 01:17 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Quote:
Welcome to FTE
Not sure if you realized the last post was in 2011?
Air suspension - rear not filling V8SHO 1997-2006 Expedition & Navigator 19 11-14-2016 11:27 AM
Air bags on a 2WD F350 - not possible? swarf_rat 6.7L Power Stroke Diesel 20 03-19-2016 01:04 PM
Air bags on a saggy Ex pirate4x4_camo Excursion - King of SUVs 15 11-30-2015 05:38 PM
SuperCrew Sag 96f150 1997 - 2003 F150 1 10-28-2015 10:45 PM
'07 Radio volume goes to zero by itself gpfarrell 2007 - 2014 Expedition & Navigator 2 06-16-2015 10:31 PM
Tags
1999, 19992002, 2002, air, compressor, expedition, failure, location, navigator, overnight, rear, sags, suspension, system, troubleshoot, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
