Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-28-2008, 03:36 PM
arnbobold is starting off with a positive reputation.
1950 F6 flathead 6 engine ID'ing
My father has the 50 F6. He uses it for tree work, it has a boom and winch mounted on it. It recently started making a knocking noise. He said he started it the other day, after sitting for several months. It didn't start knocking again until it got warmed up. Dad is 81 and has been doing tree work since the 50's.
Not always exclusively, but as a supplimental income. He's torn between replacing the truck and fixing this one, but at his age does'nt want to spend alot of money say buying a new engine.
This truck like I say is the f6 with the flathead 6. He just replaced the hydro-booster, and has the 2-speed rear.
If I could ask, what might the problem be. It knocks all of the time. He says it still has oil pressure. Not sure of how much. The truck is 25 miles from me.
How do I check to see what the size of the engine is? From what I've read, it sounds like maybe a 226 "H".
Any help on ID'ing the engine would be much appreciated. Also, would like to know what people think is the problem and the cure. To me, it sounds like a bearing problem of some sort.
He's had this truck for over 40 years. Thanks in advance, Bob!!
  #2 (permalink)
Old 03-28-2008, 05:28 PM
effie_man's Avatar
Fatty driving the Flatty!
effie_man is starting off with a positive reputation.
http://www.vanpeltsales.com/FH_web/f...0to125late.htm
http://www.vanpeltsales.com/FH_web/f...ialnumbers.htm
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #3 (permalink)
Old 03-28-2008, 08:51 PM
Snowking's Avatar
More Booze Less Guilt
Snowking is gaining momentum as a positive member of FTE.Snowking is gaining momentum as a positive member of FTE.
It would prob be a 226 yes that was a very common motor in its day.
__________________
only the finest junk around
2000 Ford F150 Supercab
1946 and 1947 Mercury 1/2ton
1949 Mercury M47
1951 Mercury M-6
1952 F-1
1953 F250
1956 Ford F100
1957 F250
1964 Mercury M100
1967 & 69 F100
4 old Internationals/ Dodges (Hey, Nobody's perfect)
  #4 (permalink)
Old 03-28-2008, 09:31 PM
51ford fan's Avatar
51ford fan is starting off with a positive reputation.
The 226 should have OHA or 7HA cast on top of the head. The 254 will have 8HA cast on the head. On the block between the generator, and the oil filler tube, just above the pan rail, is the block number. The first of the engine serial number will be 7HA if it's a 226, or 8HA if it is a 254. If it's a 254 grab it, there is a rather small almost cult like following for this Flathead 6. Some say they were Henry's best kept secret, and the way my 226 has continued to suprise me I have no reason to doubt that statement.
Good Luck
__________________
Rod 51 F1 Truck
Flathead 6
S-10 5-Speed
"Keep on Truckin"
  #5 (permalink)
Old 03-29-2008, 04:19 AM
55 f350's Avatar
55 f350 is starting off with a positive reputation.
i got a 226 outta of a 48 1/2 ton that ran perfect when it was pulled about 5 years ago . its inside and has been since being pulled . i dont really know what the hades im doing with it as i got to many things to do on the 53 i drive and seeing as no one wants ol smiley , my 49 f-4 i need to get it up and running so i may sell it, the 6 that it is . i do not get greedy so if i do are ya interested in that 6 ?? its a 226 flatty . later .
__________________
thats because were all opinionated bullcrap artists looking for somewhere to espout our views and show the world how much we { dont } know especially to newcomers. were on a mission to impress you and make you beleive we are all knowing !
  #6 (permalink)
Old 03-29-2008, 06:58 PM
WOW, thanks so much for all the information all. I'll have to get over and see which engine is in it. And to 55 f350. I very well could be interested in your motor. I need to talk to dad and see if he wants it. Send me either a PM or e-mail with the price. Your engine will work OK in the F6? I know his engine looks small for the size of the truck. As long as it will bolt up to what he's got, that would work I'm sure. So whats the knocking noise in your opinions?
Once again a big thanks to all for your input and information. Bob
  #7 (permalink)
Old 03-29-2008, 08:38 PM
Snowking's Avatar
Should work just fine in the F6.
__________________
1949 Mercury M47
1951 Mercury M-6
1952 F-1
1953 F250
1956 Ford F100
1957 F250
1964 Mercury M100
1967 & 69 F100
  #8 (permalink)
Old 03-29-2008, 09:47 PM
55 f350's Avatar
worse case scenario a rod knockin' away . i tried to send you a pm and it says you cant receive them prolly cause yer a newbie . so let me see what im gonna do and i'll be honest probably like 250 -300 at the most . i dont know if its outta line , but its complete save for a broken exhaust manifold now , another story for another time ! like i said give me a couple to figure it out but id say i will i gotz to much stuff stuck here and there now .
__________________
  #9 (permalink)
Old 04-01-2008, 06:52 PM
I just got back from checking out dad's truck. The numbers on the head were: 8 MTH - 6050 - B . So that would be the 254 cube "M" Series, is that correct? He started it and it did start knocking after running about 5 minutes,
or until the oil got warm. So, bearing failure huh? Thats what it sounds like to us. So, would this 226 be a easy bolt-in for this swap. I don't think the difference in power should hurt him much since he don't drive it far from where he keeps it. He uses it to pull trees over, lift logs, and brush. I was reading about the early and late versions of the blocks. One had a thin flange and the other 3" wider. I could use somemore input on this swap
from you guys that are expierenced. And it would be much appreciated. Bob
  #10 (permalink)
Old 04-02-2008, 11:57 PM
51ford fan's Avatar
Bob you are correct, that is the 254 Flathead engine. The difference between the 226 and 254 is internal, the 226 should be a direct bolt in. I'm interested in possibly purchasing the 254 from you if you want to sell it. Shoot me an e-mail message Ikkyu5149 @ Lycos . com no spaces
__________________
Rod 51 F1 Truck
Flathead 6
S-10 5-Speed
"Keep on Truckin"
  #11 (permalink)
Old 04-03-2008, 07:11 PM
I'm sure it will be available as soon as we get another motor. 55 f350
keep diggin when you get a chance. Did you get my e-mail? He told me today he had some other people looking around here, not sure it will pan out. He
found a V8 in a pick-up. But, what kinda hassel would that be to hook-up.
He's got a 39 pick-up radiator, but I'm sure thats to small for the f6. Mounts are different also aren't they? I'm thinking he might want to stick to the 6.
Bob
  #12 (permalink)
Old 04-30-2008, 03:25 PM
UPDATE: We found a 49 F5 with the V8. If the price is right looks like we're
going to change motors. The F5 has a better body, but we noticed it had the 2 speed rear under it (unhooked). He talked to the mans wife only so far, waiting to talk to the husband about the truck. If looks count, the engine looks real good. But, want to hear it run first. Bob
  #13 (permalink)
Old 05-29-2008, 03:26 PM
Not going to the V-8. Going to the 48 226 instead. Does anyone know if the f6 transmission is 10 spline? Not sure if the 254 flywheel will fit the 226, or if the 226 clutch set-up is going to fit the f6 trans. Just preparing for the swap and not looking for any surprizes. I know they are about the same engines except the insides. But the crank could be different? HELP Bob
  #14 (permalink)
Old 07-04-2008, 05:00 PM
I found out the f6 trans is also 10 spline. And the operation is over and complete and now the 1950 f6 winch truck is back on the job. The 226 is running sweet, with more than enough power for the job. Both the 226 and the 254 are very powerful engines. I
honestly can't tell alot of difference. Thanks fella's, thanks 55 f350. That engine is so
much better off in the truck than in your Moton building just sitting.
1950 f6, with a 48 f1 engine. Who needs a 254 to re-build? Hate to send it to the scrap yard. Junks at 260.00 a ton, but hate to see this rare engine go there. Bob
  #15 (permalink)
Old 07-04-2008, 05:57 PM
55 f350's Avatar
you are welcome and contact a guy via pm that goes by cass . he's looking for a six for his f-4 bob .
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
