Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 03-28-2008, 01:38 PM
rbook rbook is offline
rbook is starting off with a positive reputation.
Engine Problem (Loss power and ideling bad)
I have a 99 Ford Ranger 2wd with the V6 3.0 engine. The other day when I was on my way home I started loosing power. I thought I had a flat so I pulled over and check my tires no flat. Engine was running good etc. Started back on the 4 lane and went about another 2 miles and was loosing more power.. Pulled over and the truck was ideling rough (even less power).
Got the trucked trailered in to my house.
Put the truck on a computer and it read bad DPFE sensor.
Changed the DPFE Sensor, Plugs, and Wires. Truck still ideling bad with no power. I pulled the 2 O2 sensors on the manifold thinking my Catalytic convert was stopped up but still runs the same.
Also, when the engine gets to Normal temp it starts smoking Blue - Grayish smoke with a funny smell.
I am stumped on what to check next. Also the computer shows no Codes.
Any thoughts would be appreciated
(edited 3-28-2008)
Never ran Hot or low on Oil
  #2 (permalink)
Old 04-14-2008, 09:39 AM
78fordman's Avatar
78fordman 78fordman is offline
78fordman is starting off with a positive reputation.
do a compression test and a leak down test, sounds to me like you blew a head gasket between the cylinder and the valley and its sucking oil and burning it.
__________________
2000 F-150 4WD Auto, 5.4, ex Cab
1970 f-100 2wd, 4 speed, 425hp 390
Proud To Be a High Plains Drifter
Tried true 'n blue
  #3 (permalink)
Old 10-17-2008, 04:03 PM
98_danger_ranger's Avatar
98_danger_ranger 98_danger_ranger is offline
98_danger_ranger is starting off with a positive reputation.
^agreed. i would do what he said!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
