Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel Sponsored By:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-28-2008, 09:45 AM
tippmann87's Avatar
tippmann87 is starting off with a positive reputation.
EGT gauge question
I installed my EGT gauge yesterday but have one problem....it doesn't work hahahah. I got the gauge to light up and dim with the instrument panel, but can't get it to actually read. My problem is I don't know where a 12v ignition controlled supply is. Anyone know what color wire to use? I was just going to use a vampire clip. Thanks again
__________________
Support Law Enforcement; Donate to the National Law Enforcement Officers Memorial Fund (NLEOMF) http://www.nleomf.com/
"It's not how these officers died that made them Heroes; it is how they lived."
2006 F250 Lariat PSD
SCT X3 w/ Spartan Tunes
ARP Head Studs
ISSPRO Pyrometer
Short throw shifter
Good Year Wranglers
Magnaflow 4" turbo back exhaust
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-28-2008, 10:47 AM
jmaskew is starting off with a positive reputation.
I have a 2004 and I used these instructions from Dieselmanor.com which were 100% accurate for my truck.
http://dieselmanor.com/diy/PSD3-gauge/image34.htm
Get these connectors for the wiring at Lowes or another hardware store they work great.
http://www.naturallighting.com/image...connectors.jpg
__________________
Jonathan
2004 F250 PSD SB King Ranch 4x4:Build Date: 01/23/2004
Dieselsite Coolant Bypass Filter
Fumoto Oil Drain Valve
High Idle Mod
Quad overhead pod:Isspro 40 PSI Boost, Water Temp, Oil Temp and Trans Temp
  #3 (permalink)
Old 03-28-2008, 10:50 AM
tippmann87's Avatar
[quote=jmaskew]I have a 2004 and I used these instructions from Dieselmanor.com which were 100% accurate for my truck.
http://www.naturallighting.com/images/cat_image/quick_connectors.jpg[/QUOTE]
I tried using those instructions when I did it, but it doesn't seem accurate on my truck.........
__________________
ARP Head Studs
ISSPRO Pyrometer
Short throw shifter
Good Year Wranglers
  #4 (permalink)
Old 03-28-2008, 12:49 PM
Quote:
I'll take some pictures later today and get them posted to see if it helps.
__________________
Jonathan
High Idle Mod
  #5 (permalink)
Old 03-28-2008, 05:59 PM
Tippman, take a look in my gallery. I posted some pictures. Hope they help.
__________________
Jonathan
High Idle Mod
  #6 (permalink)
Old 03-28-2008, 10:59 PM
tippmann87's Avatar
Thanks for the pics. I think the earlier 6.0's are a little different. I have searched all over in my 2006 for the red/yellow wire and can't find it. The wire I used for the dimmer is not yellow either, i can't remember what color it was, but it deff was not yellow bc it was two colors.
__________________
ARP Head Studs
ISSPRO Pyrometer
Short throw shifter
Good Year Wranglers
  #7 (permalink)
Old 03-29-2008, 12:47 AM
rotun's Avatar
rotun is starting off with a positive reputation.
was your illum. wire light blue w/ red trace? if so the 12v ign. src. will be the heavy red w/ black trace on the white conn. mounted to the bottom of column mount just above the gear indicator adjustment.
__________________
'07 f-350 CC LB Harley
SoCal/Hawai'i FTE
Join our Chapter
*HERE*
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
