can't find a new harmonic balancer?!? - Ford Truck Enthusiasts Forums
Old 03-27-2008, 06:19 PM
camccardell's Avatar
camccardell camccardell is offline
camccardell is starting off with a positive reputation.
Cool can't find a new harmonic balancer?!?
ok, I guess I need a new harmonic balancer for my 96 f-150. The problem is, no one has one. They sell them for bo*th the 5.0 and 5.8 (I have a 5.8) but they don't have the tone ring on em for the cranshaft position sensor (aka misfire sensor)
Anyone have any idea on where I can get one?
I also need the pickup sensor which I was able to find, but not the timing indicator that goes over it.
Ford says they can order one, but they are not sure if it what I need, but it is $240, which is a hellofa lot of coin for a stock dampner.
really at a loss here, any help would be appreciated.
Old 03-27-2008, 07:24 PM
Trevor1's Avatar
Trevor1 Trevor1 is offline
Trevor1 is starting off with a positive reputation.
rockauto.com has it for 62.79
Old 03-27-2008, 07:36 PM
it dosen't have the tone ring on the back of it.
it's just like all the local part stores, no tone ring and I need one
Old 03-27-2008, 07:53 PM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
Wink
Call the Damper Doctor at (530)246-2984 may be they can help?? they are in Redding, CA and they just rebuilt my original balancer for my 1965 289 HIPO.
Great Folks to deal with!!!
Old 04-05-2008, 06:21 PM
Exclamation
ok I found some balancers, but I have interchange questions.
I need a f6te-ja. I found these 3 balancers, but I am not sure if they would work
ENGINE TYPE : FORD 302/351 1981-UP F/N E2TE-D3A, E1TE-E3A 4 BOLT PULLEY 1 1/2" RING WIDTH 5/8" PULLEY HEIGHT STARWHEEL ON DAMPER TIMING @ 30 DEGREE COUNTER CLOCK PART # FO302-5
ENGINE TYPE: FORD 302/351 1980-UP F/N EOAE-F1A , EOAE-F3A TIMING @ 60 DEGREE COUNTER CLOCK 4 BOLT PULLET PULLEY HEIGHT: 7/8" RING WIDTH : 1 1/4" STAR TIMING WHEEL PART # FO302-6A
ENGINE TYPE : FORD 302/351 81-UP F/N E1TE-C3A ECC TIMING WHEEL RING WIDTH 1 1/4" 7/8" PULLET HEIGHT 4 BOLT PULLEY TIMING 30 COUNTER CLOCK PART # FO302-6
DamperDudes.net (Americas Largest supplier of harmonic balancers)
I've dropped em a message, hopefully I'll hear something back soon, but I'll probably have to wait till monday. Any info from you guys is always appreciated.
Old 04-08-2008, 02:11 PM
I've talked to em and apparently they cannot help me
Harmonic balancer frankiethethumper Modular V10 (6.8l) 5 05-01-2015 06:28 AM
Harmonic Balancer for 223 6 cylinder MIKEDEL 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 12-15-2011 06:43 PM
ford 4.1 [250] 6 cylinder harmonic balancers vone2 Ford Inline Six, 200, 250, 4.9L / 300 4 09-21-2011 09:39 PM
Parts help needed - 5.8 harmonic balancer 1996 vs 1995 or older mb_01sc 1987 - 1996 F150 & Larger F-Series Trucks 9 06-30-2010 02:52 PM
400 Harmonic Balancer/Crakshaft Bolt urif250 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 6 05-31-2002 08:15 AM
Tags
1996, 351w, balancer, bronco, e1tee3a, eec, f6teja, find, ford, harmonic, ring, tone
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
