How to install my TW chip
Open Hood, Remove #9 MAXI fuse (kills PCM) remove the 3 13mm (I believe) that hold the parking brake on. Pull the cover off the back of the computer. Carefully clean the contacts with scotch-bright pad or the like(both sides). Install chip, carefully run the wires up and out. Install brake. DONE!
EDIT: ALSO there are no such things as stuid questions!!! We all need to learn somehow!!!
-Robb
-Robb
