38-48 v8 Flathead gearbox
Hi, i have a 38-48 flathead. the one with the bellhousing cast into the block with the closed drive gearbox. is there any adapter or a way to make it open drive to use a normal propshaft with the gearbox, or is there an adapter or a way to use a different gearbox? (maybe a C4 auto box) any home modifications i can do before i spend alot of money. Im in England and i dont think theres anything i can just buy as an adapter or conversion kit over here. Only place i can think of is Flat O Matic but after shipping and everything it is going to be real expensive. would prefer to go auto because im lazy . I will stick with my manual box for now if theres an easy way to use a standard prop.
Thank You!
Thank You!
Fordx4jake
05-31-2015 12:02 PM
DigitalCrossbow
11-27-2014 02:51 PM
OilLeaks
41
12-28-2011 12:00 AM
