MAF conversion '90 F150 302 AOD
Old 03-26-2008, 09:09 PM
skarpenz's Avatar
skarpenz
skarpenz is offline
I want to do a MAF conversion on my pickup, but I'm really not willing to put 1200$ into it just to do so as per these directions/guidelines:
http://bjoern.brembs.net/cars/maf_conversion/
I don't mind doing work, how can I do this conversion without spending a small fortune? If its gonna cost more than $750 then I'll just convert it to carburetor like I had planned after the stroker build. Everyone online apparently uses some expensive sub-harnesses and stuff.
Old 03-26-2008, 09:18 PM
Conanski's Avatar
Conanski
Conanski is offline
This can be done with junkyard parts. You need a mustang computer, MAF meter, and a wiring harness to pull the wires you need from. These can then be plugged into your existing truck harness and you're good to go. The biggest apparent problem is getting the wires out of the EEC connector without trashing the pins, but even this is no big deal with an extraction tool. You'll find these at electonics parts stores and online. The tool slides on over the wire and when you push it up into the back of the connector it depresses the little barbs that keep the pin in the connector block, the wire then easily pulls out of the block without damaging the pin.
Intimnasc
01-25-2015 11:14 AM
Duramaxfanatic1
05-15-2011 04:12 PM
JB_85F150
06-17-2010 07:16 PM
bryanb70
1978 - 1996 Big Bronco
10-28-2008 02:43 PM
solidrunner
11-02-2006 06:11 PM
Quick Reply: MAF conversion '90 F150 302 AOD
