Pinion Nut Size?? - Ford Truck Enthusiasts Forums
Pinion Nut Size??
Old 03-26-2008, 05:54 PM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
Wink Pinion Nut Size??
Would anyone know what size the BIG nut is that holds the rear pinion yoke on?? (1999 F350 Dually 2wd) I think its the bigger of the 2 rear ends because its a Dually I even tried my BIG 1 1/2" socket that I use on hitch ball nuts and IT is TOO small!! Does it take a special socket?? thin wall?? it doesn't look like it needs to be a deep well???? Thanks!!
Old 03-27-2008, 07:25 AM
Wink
BUMP...anyone know??
1999 F-350 dually 2wd pinion nut mustangmatt 1999 to 2016 Super Duty 1 04-10-2014 09:44 AM
socket size for lug nut macguy 6.7L Power Stroke Diesel 12 06-29-2012 09:26 AM
01 f450 pinion nut size NeckDlight 1999 to 2016 Super Duty 2 01-04-2011 10:15 AM
Tightering the pinion nut pikiluvi Clutch, Transmission, Differential, Axle & Transfer Case 5 11-04-2006 01:53 PM
Rear pinion nut size? superrangerman2002 Ranger & B-Series 2 07-19-2003 09:34 AM
Tags
03, 07, 2000, 2003, 350, dually, f250, f350, ford, nut, pinion, rear, size
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
