Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-26-2008, 04:51 PM
xtreme xtreme is offline
Garage is empty, add now
xtreme is starting off with a positive reputation.
38-48 v8 Flathead gearbox
Hi, i have a 38-48 flathead. the one with the bellhousing cast into the block with the closed drive gearbox. is there any adapter or a way to make it open drive to use a normal propshaft with the gearbox, or is there an adapter or a way to use a different gearbox? (maybe a C4 auto box) any home modifications i can do before i spend alot of money. Im in England and i dont think theres anything i can just buy as an adapter or conversion kit over here. Only place i can think of is Flat O Matic but after shipping and everything it is going to be real expensive. would prefer to go auto because im lazy . I will stick with my manual box for now if theres an easy way to use a standard prop.
Thank You!
  #2 (permalink)
Old 03-26-2008, 10:34 PM
Snowking's Avatar
Snowking Snowking is offline
1950 Mercury M47
Snowking has a very good reputation on FTE.Snowking has a very good reputation on FTE.Snowking has a very good reputation on FTE.
I'm not sure on auto transmitions. sorry
BUT
What I find is popular to run behind flathead motors if you have the funds/will to do it is to use a T5 tranny from a Chevy S10. There are many books on doing this swap.
__________________
Some nights you just have to realize your gonna be slaying a Dragon and not saving the Princess
  #3 (permalink)
Old 03-26-2008, 10:59 PM
effie_man's Avatar
effie_man effie_man is offline
1953 Ford F-100
effie_man is gaining momentum as a positive member of FTE.
there are adapters for almost any popular transmission to bolt to the flatty. If you do a search on the net for them something will come up. They range in price from a couple hundred to a couple thousand depending on what tranny your adapting. Ebay is another option. Hope this helps
__________________
Chris
1953 Ford F100 Custom Cab
1950 Mercury Monarch Sports Sedan
1949 Mercury Monarch Lead Sled Full Custom
2004 Ford F150 STX 4x4
  #4 (permalink)
Old 03-27-2008, 01:39 PM
any idea which books might have some info on a swap? i have seen a speedway conversion plate but its for the later flatty without the bellhousing cast into the engine block.
  #5 (permalink)
Old 03-27-2008, 05:48 PM
effie_man's Avatar
1953 Ford F-100
that one might be tricky, ill take a look around in some of mine and see if i can dig anything up for you.
__________________
Chris
  #6 (permalink)
Old 03-27-2008, 09:23 PM
Snowking's Avatar
1950 Mercury M47
Here bud
these guys make adapters for C4's among others.
http://www.flat-o.com/
__________________
Tags
34, 48, adapter, drive, f1, flat, flathead, ford, gearbox, gm, head, open, t5, transmission, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
