Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-26-2008, 04:51 PM
xtreme is starting off with a positive reputation.
38-48 v8 Flathead gearbox
Hi, i have a 38-48 flathead. the one with the bellhousing cast into the block with the closed drive gearbox. is there any adapter or a way to make it open drive to use a normal propshaft with the gearbox, or is there an adapter or a way to use a different gearbox? (maybe a C4 auto box) any home modifications i can do before i spend alot of money. Im in England and i dont think theres anything i can just buy as an adapter or conversion kit over here. Only place i can think of is Flat O Matic but after shipping and everything it is going to be real expensive. would prefer to go auto because im lazy . I will stick with my manual box for now if theres an easy way to use a standard prop.
Thank You!
  #2 (permalink)
Old 03-26-2008, 10:34 PM
Snowking's Avatar
More Booze Less Guilt
Snowking is gaining momentum as a positive member of FTE.Snowking is gaining momentum as a positive member of FTE.
I'm not sure on auto transmitions. sorry
BUT
What I find is popular to run behind flathead motors if you have the funds/will to do it is to use a T5 tranny from a Chevy S10. There are many books on doing this swap.
__________________
only the finest junk around
2000 Ford F150 Supercab
1946 and 1947 Mercury 1/2ton
1949 Mercury M47
1951 Mercury M-6
1952 F-1
1953 F250
1956 Ford F100
1957 F250
1964 Mercury M100
1967 & 69 F100
4 old Internationals/ Dodges (Hey, Nobody's perfect)
  #3 (permalink)
Old 03-26-2008, 10:59 PM
effie_man's Avatar
Fatty driving the Flatty!
effie_man is starting off with a positive reputation.
there are adapters for almost any popular transmission to bolt to the flatty. If you do a search on the net for them something will come up. They range in price from a couple hundred to a couple thousand depending on what tranny your adapting. Ebay is another option. Hope this helps
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #4 (permalink)
Old 03-27-2008, 01:39 PM
any idea which books might have some info on a swap? i have seen a speedway conversion plate but its for the later flatty without the bellhousing cast into the engine block.
  #5 (permalink)
Old 03-27-2008, 05:48 PM
effie_man's Avatar
that one might be tricky, ill take a look around in some of mine and see if i can dig anything up for you.
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #6 (permalink)
Old 03-27-2008, 09:23 PM
Snowking's Avatar
Here bud
these guys make adapters for C4's among others.
http://www.flat-o.com/
__________________
1949 Mercury M47
1951 Mercury M-6
1952 F-1
1953 F250
1956 Ford F100
1957 F250
1964 Mercury M100
1967 & 69 F100
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
