How much magnesol?
Old 03-26-2008, 04:38 PM
secondarychaos's Avatar
secondarychaos
secondarychaos is offline
How much magnesol?
I've decided to use magnesol...
but how much do i use???
Thanks,
Dan
Old 03-26-2008, 06:05 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
If you do not remove the Methanol first; 2% by weight. I recover the methanol first, then filter out the soap, then use only 1% by weight.
Old 03-31-2008, 05:55 PM
secondarychaos
Ok, when you say remove the methanol, is that before or after draining glycerine?
Old 03-31-2008, 06:06 PM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
1 drain glycerol
2 recover methanol from BD
3 wash BD with magnesol
4 recover methanol from glycerol
steps 3 & 4 can occur simultaneously
Old 07-29-2008, 07:07 AM
TxFordGuy's Avatar
TxFordGuy
TxFordGuy is offline
will magnesol remove the water in the oil as well? i am having a problem dewatering my oil and my water in fuel light keeps coming on in my truck? I also have recently been informed that all my methanol is not getting out of my bio either. could maybe i don't have water and it is the extra little bit of methanol cause my light to come on? i am trying to make some good bio and am thinking of switching to magnesol. thanks
Old 07-30-2008, 08:54 AM
Knotwild's Avatar
Knotwild
Knotwild is offline
Don:
Are you filtering your Magnesol out or running a centrifuge? I have been filtering first with gravity through socks and then pulling the fuel by vacum through 1 micron Biotek filters. It works, but without pressure (since I am using vacum) the filters stop flowing too quick. I am debating buying a Dieselcraft centrifuge or a bag filter housing.
Your thoughts are appreciated.
PS: I use 2 grams/liter after removing methanol.
Old 07-30-2008, 09:37 AM
fabmandelux
Originally Posted by Knotwild
Don:
I filter out the Magnesol. I use 3 filter housings, and an air powered diaphragm pump to force it thru them. The first is 50 microns, it then goes directly to a duel 10 micron setup with a pressure switch, and a electric valve. When the pressure increases to a preset level the pressure switch opens the valve and diverts the bio to the second filter automatically and lights a red light that lets me know to switch out the first filter. After I've filtered to 10 microns I run the whole batch through a 5 micron, then a 1 micron absolute. I've found a used continuous centrifuge for sale at $2,500 and may buy it and switch over. Still trying to justify the $$$$$
Old 07-30-2008, 11:47 AM
Phydeaux88's Avatar
Phydeaux88
Hang in there Don, sooner or later they will give it to you.
Old 08-01-2008, 09:09 PM
Knotwild's Avatar
Knotwild
Knotwild is offline
OK. I got off topic. I use 2g/liter myself after demething. Works great.
Amish Ford
Large Truck
08-02-2016 10:14 PM
IHateCommieCars
06-28-2016 08:00 PM
Mdc9966
10-21-2015 04:43 PM
natedowney
15
11-20-2014 05:44 PM
highboy1975
Offroad & 4x4
09-21-2009 10:48 AM
Quick Reply: How much magnesol?
