Injection Pump Interchangeability Question
I will be buying an injector pump tomorrow an found a few close by. The pump that was removed is a db2831-4817 from a 90-91 E-Series.
db2831-4732 for $325
db2831-4812 for $380
db2831-4821 for $400
The desiel repair shop with the 4732 insured me that the 4732 would work the same as the other pumps above. I could find little information about the current 4817 removed or the 4732 he has in stock. Should I get the 4732 or go with another one. The injectors are new and were purchased for the 90-91 engine.
90-91 7.3 diesel engine in a 89 F-350
C6 transmission
Link with a few pics of the project
Thanks in advance for the help. This site and its members are great.
C6 transmission
DB2 4817 shows 90 to 92 with an E4OD tranny
DB2 4821 shows 90 to 92 with a manual tranny
DB2 4732 I have no idea, I do not have that number listed.
DB2 4746 was for an 87 6.9 five speed.
DB2 4541 was for 84 thru 87 with a C6 or four speed.
Make sure you can install the tranny VRV on the IP you get.
Thanks Dave.
I think the VRV was one of my previous problems. I bought a new one but wasn't quite sure where it went. I have been doing some reading and now know where it goes but don't see how it will work on the 4817. There is a small hole in the throttle shaft that passes through the IP. Is there a pin or something that goes in that hole to operate the VRV?
The 88 89 truck with a C6 lists a DB2 4812.
That is the last year I have a C 6 listed.
The E4OD also uses an electrical version (FILP sensor) of the VRV to control the tranny.
I don't know if the VRV will fit the same holes or not.
Automatics are my downfall, I have no experience with them at all in trucks.
The last automatic I owned was in a 71 Mustang behind a 302.
I ended up getting the db2831-4732 for $325
I installed it last weekend and if fired up and ran better than ever(hasn't ran in 6 years). I have a lot of other small problems such as no tach, needs sending units, abs light, exc. but it runs fine.
The guy that does all the rebuilding and bench testing/calibration said that there are over 20 different part numbers for the same db2 pump. The are all the same internaly but the fuel setting is set a little different on some. He said they set all their pumps a little high and adjust them for free if needed.
I am getting a little white smoke right at startup. Could be timing or extra fuel. It goes away in about 3-5 minutes so it definately not a big issue. Most likely normal.
I am looking at replacing my DB2-5013 ip with one of the earlier model 7.3 (DB2831-XXXX) non-turbo IPs because my core is has no value (seized head) and founda deal on one of those outright (no core required). The currently installed injectors are code E and almost new. Will this be OK ? - Thanks
Diesel Care and Performance Inc 1-800-961-9290
Most of their pumps don't require a core if you get them from ebay.
eBay Motors: Ford IH 7.3 7.3L injection injector pump NO CORE!! (item 350040903433 end time Apr-04-08 13:16:52 PDT)
I would think that pump would work fine but I would have it professionally tuned and have a pyrometer installed if you don't have one already.
Did you get your IP from Dieselcare ?
My first choice is to buy local if at all possible . My second choice is to buy online etc from a vendor that has no negative chatter on these forums .
They are Ebay seller - Dieselcare - There as some iffy comments about them on the various diesel truck forums .
Another smaller ebay dealer with good prices is Hectorwithinjectors - A diesel shop in Phoenix AZ .
Thanks
Thanks
The DB2-5013 for is non-turbo 1994 7.3 E4OD and is supposed to be matched with code E injectors .
I guess I could alternatively use DB2 4817 with a new set of code BB injectors but the currently intalled injectors have less than 10 k miles on them .
