I unplugged mine just for kicks....and there was no change. Engine ran the same, trans shifted the same (bad) and truck drove the same. Only thing it did was turn on the CEL. So whats it do?
MAP = Manifold Absolute Pressure sensor. As the name implies, it measures the pressure in the intake. Tells the PCM how much fuel to give the engine. If you unplugged it and there was no difference then you might have a problem. When the PCm sees the MAP is bad or unplugged it will resort to a preset fuel table stored in the PCM. The engine won't fall flat on it's face but It should be pretty doggy though. Look for pin holes in the small rubber line going to it or boost leaks else where.
Icebox- it's mounted on a bracket over by the heater core on the pass. side of the engine- has a 3-wire electrical plug and a rubber hose running to it. If you have a boost gauge, you probably tapped the rubber line for your boost gauge fitting.
Is that an OEM regulator or are you tricking the MAP for some reason?
Tricking the MAP sensor. Not all OBS truck do this but my truck was defueling. It felt like a gasser hitting the rev limiter and would happen at around 30-33 psi boost (peak boost for me). Doesn't set a CEL or code like the Superduties but for $25 got the regulator and fittings and set it to 25 psi and no more defueling on the top end.
What happens is the MAP sensor isn't designed for those boost numbers so it signal gets messed up and the PCM doesn't know what to do with it. So we trick the MAP sensor and move on.
MAX of 25. Actually I just looked at my webshot write and I said 20 PSI there. Now I am not really sure what its set at! I need to take it off and check one of these days.
My rig is not modified like yours. I imagine adding this regulator to my rig is not necessary at this time, right? What is causing your engine to defuel? Is it the high boost levels?
With my stock engine, I should see a maximum of what PSI boost?
