Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-26-2008, 12:47 PM
jcarlson is starting off with a positive reputation.
Boring and Stroking
How much of a horsepower and torque gain should I expect from Boring a 5.4L from a 3.55 to a 3.92? Then Stroking it from a 4.16 to 4.415?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-26-2008, 10:59 PM
elmo8641 is starting off with a positive reputation.
if that is all you are doing then not much. you need more air to feed the extra displacement. no change in air means no change in power. for your money you will get alot more power from a set of ported heads and a good exhaust.
__________________
2003 f-250sd 4x4 4.10 5.4L
1994 cobra w/ trickflow heads, 10lb turbo
  #3 (permalink)
Old 03-27-2008, 07:24 AM
I plan on changing the displacement from a 330 to a 428, dual overhead cams, high lift cams and valves, porting and polishing the heads, a 2.8 Liter Kenne Bell Supercharger, Headers, true dual exhaust, intercooler, dyno tuning, 4.10 rear end, and a 6 speed auto tranny.
  #4 (permalink)
Old 03-27-2008, 08:05 AM
Johnny Langton's Avatar
Johnny Langton is gaining momentum as a positive member of FTE.
3.70 bore is the largest you can get a modular block out to until you run out of room to seal the heads-the bore spacing is very close,and that doesn't leave much of room for overboring.
JL
__________________
1997 Thunderbird LX 4.6L/4R70W
Ported NPI heads & some other goodies
N/A and 3700 lbs
12.16@111.78
1998 F150 Supercab 4.6L/4R70W-Gone,sold to Dad.
2005 F250 Crewcab Longbed
3V V10/Torqshift 4.10LS
2001 Navigator
5.4L 32V/4R100
WANTED: OEM cat-back Exhaust from 2005-2007 5.4L or 6.8L Superduty
  #5 (permalink)
Old 03-29-2008, 12:09 AM
White Max's Avatar
White Max is starting off with a positive reputation.
Quote:
Where are you getting these numbers from?
-Rod
__________________
  #6 (permalink)
Old 03-29-2008, 01:32 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
Had to look at your profile...but didn't find the answer as to why you are asking this question.
You are headed down the wrong road with this engine.
Peruse the December 2007 Road and Track. Super Snake Mustang, bigger blower and other (unspecified in the article...) mods, 605 horse.
Stock bore and stroke.
Feb 2008 Car and Driver, 0-200-0 article. 2006 Ford GT. First place. Drives easy on the street. 10.52 @ 152 in the quarter. 0-200-0 in 26.5 seconds. Estimated HP: 1098. Stock crank, rods, pistons....
In these two cases, why wouldn't they add displacement instead of bigger blowers or twin turbos?
Perhaps you should do more research.
  #7 (permalink)
Old 03-30-2008, 12:41 AM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Because of forced induction and 4V heads???
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #8 (permalink)
Old 03-30-2008, 02:29 AM
The OP says he wants to use a supercharger.
I think Ford developed these engines with supercharging in mind. Now the GT engine is probably the recipient of some special parts when it is sold at the stock 500 horse level. That those parts live at 1000 horse is pretty impressive. The Shelby at 605 STILL HAS A WARRANTY. They will up it to 725 w/o warranty.
As pointed out earlier, you really can't do a big overbore, and why add stroke when you are already over 4"?
On these motors, it seems like you add boost, not cubes.
  #9 (permalink)
Old 03-30-2008, 06:08 PM
LxMan1's Avatar
I agree. The stroke is way too long. A 460 is only 3.85" vs 4.17" for the 5.4L.
The new 6.2L should be a great engine when it is released!!
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #10 (permalink)
Old 03-30-2008, 07:49 PM
can't go that big with a 5.4. they don't make a 6speed auto. not yet atleast. do you know how much money all this is going to cost you? i don't know what your goal is but you better have a big wallet to do what you want. what kind of power are you wanting to get?
__________________
  #11 (permalink)
Old 03-30-2008, 08:24 PM
LxMan1's Avatar
Yep, about .020 over is all the block will allow.
Go to www.boss330racing.com for 5.4L power.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #12 (permalink)
Old 03-31-2008, 12:15 PM
Big Bad is gaining momentum as a positive member of FTE.Big Bad is gaining momentum as a positive member of FTE.
Quote:
Seeing as how the Modulars only have a 3.94" bore spacing, a 3.92" bore would leave you with no cylinder wall. No cylinder wall no power.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
