Occasional clunk on take-off - Ford Truck Enthusiasts Forums
Old 03-26-2008, 11:26 AM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
Like the title says, I have an occasional clunk on take-off. Not really bad or excessively loud, but definitely noticeable. It's hard to figure out because it doesn't do it every time, only every so often. My best guess says its the infamous Super Duty clunk, but could it be something in the rear end or even something worse? Would tired gear oil in the diff cause the LS to clunk like this? I'm hoping to grease the slip joint soon to see if it is in fact Super Duty clunk. Is there any need to cut/replace the clamps on the rubber boot when I do this?
Old 03-26-2008, 11:30 AM
twags6's Avatar
twags6 twags6 is offline
PAA Member #7 and FTE
twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.
IIRC, you have to cut the metal tie off the bottome of the boot. Just replace it with a zip tie when you're done. Check your u joints while you're under there too and grease everything with a zerk fitting.
Old 03-26-2008, 12:09 PM
I've yet to find a single grease zerk anywhere but the steering linkage on the truck, I think that's pretty typical anymore. A zip-tie will seal the boot tight enough?
Old 03-26-2008, 12:14 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Remember that there are several sizes of zip ties.
Use a big one.
What I did was to use two of the larger-size, stainless, screw clamps (the ones for fuel lines), screwed together to make it longer.
Pop
Old 03-26-2008, 12:38 PM
Quote:
Use a big one.
Pop
Are you talking about just a regular screw-type hose clamp, or some kind of special fuel line hose clamp?
Old 03-26-2008, 12:55 PM
ggirten ggirten is offline
ggirten is starting off with a positive reputation.
If it only does it occasionally and at take off, then it could be a sticky brake. Not as likely with 4 wheel disk, but possible.
Old 03-26-2008, 12:59 PM
The fuel line screw clamps are just like the ones for radiator hoses, just thinner and shorter (smaller).
Pop
Old 03-26-2008, 01:04 PM
guitarpicr's Avatar
guitarpicr guitarpicr is offline
guitarpicr has a very good reputation on FTE.guitarpicr has a very good reputation on FTE.guitarpicr has a very good reputation on FTE.
Has any one ever installed a zerk fitting on that housing. Im thinking @ trying it as its a pita to take that off and grease every 6-8 months.
Old 03-26-2008, 01:08 PM
twags6's Avatar
Quote:
My 88 f250 had one. Someone mentioned drilling and tapping one in there, but the question was would it put it off balance? I guess you could always put one in, and put another one on the opposite side for balance.
Old 03-26-2008, 08:47 PM
Pop
Old 03-26-2008, 09:08 PM
nhill2090 nhill2090 is offline
nhill2090 has a very good reputation on FTE.nhill2090 has a very good reputation on FTE.nhill2090 has a very good reputation on FTE.
i tried carefully taking off the metal clamps and re-installing them. Let me save you the time of trying and just say zip tie it
Old 03-26-2008, 09:10 PM
Zip-ties it shall be then
Old 03-26-2008, 09:12 PM
Quote:
Good to hear
Old 03-26-2008, 09:33 PM
slappysdump slappysdump is offline
slappysdump is starting off with a positive reputation.
You may want to check the u-bolts on your steering stabilizer while you are under the truck. I had a "clunk" coming from the front of my F-350 and found that they had worked loose. I replaced the whole thing because I could push the ram in w/ little force, but tightening the bolts would have have fixed the clunk. Good luck tracking down the source of your "clunk".
Old 03-26-2008, 10:01 PM
Thanks slappy, I'll check that as well.
1999 ford E250 slip yoke clunk? CopperBurst 1968-2013 Full Size Vans 5 03-21-2015 07:25 AM
Clunk Clunk Clunk noise on takeoff Aune163rd Modular V10 (6.8l) 6 08-15-2012 07:57 PM
Driveline Clunk on stop and go Squiggy Clutch, Transmission, Differential, Axle & Transfer Case 19 07-13-2007 09:28 PM
?? for rear clunk experts Beanpod 1997 - 2003 F150 12 04-01-2007 11:43 PM
popping-clunking sound upon take-off tmorgan2 1999 to 2016 Super Duty 5 12-12-2003 04:21 PM
Tags
1999ford, 2002, 250, bed, clunk, clunking, duty, end, f250, f350, ford, il, joint, lubew, rear, slip, starting, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
