Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 03-25-2008, 10:23 PM
newbe-rebuilder newbe-rebuilder is offline
Garage is empty, add now
newbe-rebuilder is starting off with a positive reputation.
Question Catalytic converter Cherry Red!!!!
I have a 95 F150 4X4 5.0 5 Speed. 186,000 mi. Over the last couple months when starting off cold the engine would sputter (?) and cut out, but after the RPM would rise it would clear up. About a week ago it started to cut out through at all speeds and RPM, hot or cold. I was thinking fuel filter or spark plugs. Maybe a bad guess on my part, but anyway. Tonight I replaced plugs, wires and distributer. I dont know if I done something really wrong but it is worse ( will hardly run at an idle) and after about 10 minutes the exhaust pipe gets Cherry Red at the exit side of the catalytic converter!!!! I tripple checked the order of wires. It is correct! What ****** have I done!! I have never even heard of this. Is the catalytic converter bad and causeing the rough engine running? How did changing sparkplugs and wires effect this and cause the exhaust to get Red? I dont even know where to start next after tonight? Should I replace the converter? Thanks ahead of time for any replies.
  #2 (permalink)
Old 03-25-2008, 10:29 PM
Greywolf's Avatar
Greywolf Greywolf is offline
WILD CARD
1989 Ford Ranger
Greywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputation
Were I you - I'd be looking and feeling all around to find an open vacuum fitting that has no line attached.
Go all around the intake manifold - especially in the back, with an inspection mirror - or if EFI, think about the idle air bleed.
Headers only do that on an extreme low mixture!
__________________
Think outside of the box - especially if you built it yourself
  #3 (permalink)
Old 03-26-2008, 01:53 AM
95F350XL 95F350XL is offline
95F350XL is gaining momentum as a positive member of FTE.
If the converter is getting red it is clogged, but your sayin its red after the cat? A clogged cat can caus the engine to have no power.
__________________
1988 Bronco XLT 5.0HO GT40 Ported&Polished,Cobra Roller Rockers,AOT, Hedman LT,Thrush Welded Mufflers,True Dual Header Back,33x12.5 Nankin Mud Stars, 15x10 Outlaw II's
1995 F350 XL 5.8 E4OD,Flowmaster True Dual, LT's,35x12.5 ProComp Xterains, MT Classic 17x9
A good analogy for the entire US auto industry, Ford pulling the whole weight, while GM and Dodge are just along for the ride while on guberment life support.
  #4 (permalink)
Old 03-26-2008, 02:40 AM
jeremiah302's Avatar
jeremiah302 jeremiah302 is offline
jeremiah302 is starting off with a positive reputation.
I would have to say that the catt is clogged up, that happened to me once before, i was pulling out and had no power what so ever and the truck wouldn't stay running at a stop sign, needles to say the catt came off and straight pipes went on..lol but that truck is gone now 'RIP' thanks to a drunk. Good luck
  #5 (permalink)
Old 03-26-2008, 04:39 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
Sounds like you have either an extremely rich mixture, or a substantial misfire, both of which will dump unburned fuel into the exhaust, where it burns, causing higher exhaust temperatures than normal. Out of curiosity, what firing order are you using?
__________________
Eric
'87 F150 302 ZF 5 speed 4x2
  #6 (permalink)
Old 06-01-2010, 09:41 PM
Bursch Bursch is offline
2002 Ford Explorer
My Garage
Bursch is starting off with a positive reputation.
Did your engine temp climb also? Mine started running like that lately the temp guage climbed like crazy. I am thinking clogged cat. I will look if it gets that hot.
  #7 (permalink)
Old 06-01-2010, 10:24 PM
Volvo92906's Avatar
Volvo92906 Volvo92906 is offline
1988 Ford F-150
Volvo92906 is gaining momentum as a positive member of FTE.
Sounds like the Cat.
__________________
enˇgine noun -a machine for converting thermal energy into mechanical energy or power to produce force and motion.
moˇtor noun -a machine that converts electrical energy into mechanical energy, as an induction motor.
  #8 (permalink)
Old 06-01-2010, 10:44 PM
rla2005's Avatar
rla2005 rla2005 is offline
2004 Ford Excursion
rla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to all
I had all 4 cats glowing red on my last '93 Lightning when the PIP was acting up. I would also question how the timing was set?
  #9 (permalink)
Old 06-02-2010, 09:19 AM
subford's Avatar
subford subford is offline
subford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to behold
I can see extremely rich mixture (FPR, O2 sensor , ...), or a substantial misfire (PIP), both of which will dump unburned fuel into the exhaust but I do not see how a clogged converter will cause it to get RED.
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #10 (permalink)
Old 06-02-2010, 10:03 AM
Volvo92906's Avatar
1988 Ford F-150
Quote:
I was always informed that no power and glowing red cat were signs it was bad (clogged). Im not gonna go against you. I could learn me something new here.
__________________
  #11 (permalink)
Old 06-02-2010, 10:26 AM
subford's Avatar
I can see bad timing doing it also.
I have heard it also that a clogged converter will cause the converter to get RED.
But do not understand how a clogged exhaust system will cause anything to get red.
__________________
subford@gmail.com
  #12 (permalink)
Old 06-02-2010, 10:38 AM
Vacationtime247 Vacationtime247 is offline
1989 Ford F-350
Vacationtime247 is starting off with a positive reputation.
If your state does not have emissions testing, cut off the exhaust behind the catalytic converter. Take a breaker bar or long hard metal object and poke through the cat. Keep doing this until all the guts inside the cat have been broke free. Start the truck and blow it all out. Put in a sleeve and some u-bolts. More power and will probably fix the problem. Had a van with this problem and I just ran a straight pipe. Problem solved.
VT247
  #13 (permalink)
Old 06-02-2010, 10:41 AM
Hitokori's Avatar
Hitokori Hitokori is offline
Hitokori is gaining momentum as a positive member of FTE.
timing being off will cause the manifolds to glow if the cat is just glowing its clogged... so either bust it out or replace it with a new one or a piece of pipe
and it causes the cat to glow because the hot gasses build up and cant escape so it will heat the cat and exhaust pipe up so much it glows and can develop leaks
__________________
Matt
Whats the diff between your wife and your job? After 10 years your job still sucks
  #14 (permalink)
Old 06-02-2010, 10:49 AM
ymeski56's Avatar
ymeski56 ymeski56 is offline
ymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputation
Remove the o2 ahead of the Cat. if pressure there is more than 3 psi, back pressure! If the temp & power returns to normal while the o2 is removed, back pressure. Cat's pooched. This does not address how it got that way. #1. Running higher than 87 octane redundantly. Also, Error code scan results, are your friend!
__________________
Saving the World......One Ford truck at a Time!
"Democracy" is two wolves and one lamb voting on what's for lunch.
"Liberty" is a well armed lamb disputing the vote!
  #15 (permalink)
Old 06-02-2010, 10:51 AM
Dancingchicken Dancingchicken is offline
Dancingchicken is starting off with a positive reputation.
I remember a guy on here months ago that was pulling his hair out over what ended up being no spark to one cylinder. Turned out that one of the brand new plug wires he just installed was bad right out of the box. It was actually sort of funny to me because when he brought it back to the parts store (I think it was Autobone) he said he got in a fight with the guy at the counter over it, almost a fist-fight, lol. Now that's frustrated!
Soooo, that said, I would do more than just check the order of the plug wires you just put on, I would check each one to make sure you are actually getting spark through them. If you are, I would go with continuing to snoop around the cat being plugged. That sounds most logical at this point and with that many miles on your rig, very possible.
__________________
93 F250 XLT Supercab, Longbed, 4x4, 5.8L, E4OD
04 Mustang GT, 4.6L, Steeda Tri-Ax Short Throw, SLP Loudmouth Cat-back, Tunable Induction CAI
Tags
95, catalytic, cats, cherry, clogged, converter, exhaust, f150, hot, idle, mustang, pinging, pipes, red, rough, shut, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
