Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-25-2008, 09:52 PM
rcav8or's Avatar
If you use it, SUPPORT IT
rcav8or is starting off with a positive reputation.
distributor/cover questions
Thought I would post here first, even if it IS mighty quiet!
I know that there are two front covers, and two distributors. Which is which, how can you tell them apart, will either one of the distributors work with BOTH covers?
Not sure, but I think I have the cover that uses the distributor, that has the "extended" shaft past the gear, but, my distributor doesn't have the long end, just the gear.
Help!?!
R
__________________
Roger Phillips
Oxford, IN
Be an FTE supporter! Best $20 I EVER spent!!
Click the link for pictures of my truck:
1951 Ford F2
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-27-2008, 12:01 AM
effie_man's Avatar
Fatty driving the Flatty!
effie_man is starting off with a positive reputation.
k first off what motor are we talking about here?
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #3 (permalink)
Old 03-27-2008, 12:16 AM
rcav8or's Avatar
Quote:
Effie - we're talking about a flathead, 239, came out of a '51 car. I think I have it resolved, though - the front cover is for the "extended shaft", but I have it on good authority that it's just fine, running the distributor that doesn't have the extended shaft in it.
This came from Ross, Albuq...
Quote:
Yes, you can run the non-extended dizzy in an aluminum cover. Not all aluminum covers had the extra bushing /support at the bottom. It seems to me the Canadian aluminum front covers were straight replacements of cast iron ones, while American aluminum covers were the extended type. Could be wrong here. I'm running a MSD Ready-to-run in a Canadian aluminum (non-extended) cover.
Sorry, I tend to forget Ford made OTHER motors...
R
__________________
Roger Phillips
Oxford, IN
1951 Ford F2
  #4 (permalink)
Old 03-27-2008, 12:18 AM
effie_man's Avatar
the cover i have on my desk by the computer is an extended one
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #5 (permalink)
Old 03-27-2008, 12:19 AM
Snowking's Avatar
More Booze Less Guilt
Snowking has a good reputation on FTE.Snowking has a good reputation on FTE.
For awhile there I thought you were talking about a crab style dist. flattie when you were talkin bout 2 covers.
__________________
only the finest junk around
2000 Ford F150 Supercab
1947 Mercury 1/2ton
1949 Mercury M47
1951 Mercury M-6
1952 F-1
1957 F250
1964 Mercury M100
1967 & 69 F100
4 old Internationals/ Dodges (Hey, Nobody's perfect)
  #6 (permalink)
Old 03-27-2008, 12:21 AM
Snowking's Avatar
But I'm just surprised a 48-60 guy ventured over here........ I'm scared
__________________
1947 Mercury 1/2ton
1949 Mercury M47
1951 Mercury M-6
1952 F-1
1957 F250
1964 Mercury M100
1967 & 69 F100
  #7 (permalink)
Old 03-27-2008, 12:25 AM
rcav8or's Avatar
I had been watching for one of the aluminum ones, and it wasn't until last night, that I realized that I already HAD one!! For some reason, I thought the Canadian ones were the only aluminum...I sure have a LOT to learn! It was already painted when I got it, so I didn't know, until I pulled the dizzy out, then realized that it wasn't "right" for the cover I had, so started doing research...
Sure looks different now - truck rebuilt water pumps, truck fan and mount, new fresh paint, aluminum (maybe) manifold...but, now that all that's done, I doubt if I'll strip the front ALUMINUM (YEAH, BABY!) cover...too pretty to touch...
Thanks all,
Roger
__________________
Roger Phillips
Oxford, IN
1951 Ford F2
  #8 (permalink)
Old 03-27-2008, 12:26 AM
effie_man's Avatar
manifold is prolly cast but hey, stranger things have happened. nice looking flatty
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #9 (permalink)
Old 03-27-2008, 12:28 AM
effie_man's Avatar
does that motor have the center sump oil pan or the stepped one?
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #10 (permalink)
Old 03-27-2008, 12:33 AM
rcav8or's Avatar
Effie - that's the old picture, what it looked like when I brought it home. It was out of a car, the paint was 5 or 6 years old. You are right, that's the cast manifold on it. I have an aluminum one, I got out of Canada, that I will probably put on it. I will try to post pics tomorrow of what it looks like now. Still working on detailing it.
I'm not sure of the difference - it's out of a car. I will probably be changing over to the truck one, when I build my new stand, but might leave this one one it, at least for now. Now that I have the right pumps on it, I will be building a new stand, and using that stand for my extra block. Hope to make it a little taller, room for the tranny, battery, etc, so I can run it on the stand.
R
__________________
Roger Phillips
Oxford, IN
1951 Ford F2
  #11 (permalink)
Old 03-27-2008, 12:37 AM
effie_man's Avatar
well the truck ones are either a stepped looking pan for 51-53 (I think) trucks and then the 48-50/51 had a center sump with a really large drain plug/cleanout. The car pans are similar tot he 48-50/51 truck pans except they have a small drain plug. My truck had one of these pans on it but had to change to the correct truck pan (53) in order to lower my front end and maintain clearance to my straight axel
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #12 (permalink)
Old 03-27-2008, 12:39 AM
Snowking's Avatar
I just prefer the 48-50/1 pans cause of the removable bottom, makes it pretty dang slick to clean out.
__________________
1947 Mercury 1/2ton
1949 Mercury M47
1951 Mercury M-6
1952 F-1
1957 F250
1964 Mercury M100
1967 & 69 F100
  #13 (permalink)
Old 03-27-2008, 12:42 AM
rcav8or's Avatar
I have the truck pan, with the big cleanout that came with my truck (notice I said with and not ON!). The pan had been off forever, full of rusty bolts. This one (I just looked, and took some pics, they'll be up in a few minutes) on it is the car, with the small plug, and hump in the center...
Pics in a minute...
R
__________________
Roger Phillips
Oxford, IN
1951 Ford F2
  #14 (permalink)
Old 03-27-2008, 12:45 AM
effie_man's Avatar
tried posting pics of them but server is busy
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #15 (permalink)
Old 03-27-2008, 12:47 AM
Snowking's Avatar
As for intake though I've always prefered a aluminum one. Just dresses up the motor a little more. Are you tearing into the motor if so I recomend a 4 inch crank conversion. Just food for thought
__________________
1947 Mercury 1/2ton
1949 Mercury M47
1951 Mercury M-6
1952 F-1
1957 F250
1964 Mercury M100
1967 & 69 F100
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
