Okay, a little longer than a minute...but not much! Here's pics of the pan I have on it now, and the motor as it looks with the aluminum and stock manifold...can't decide which to use!!!
R
__________________
‹(•¿•)› Roger Phillips Oxford, IN
Be an FTE supporter! Best $20 I EVER spent!! Click the link for pictures of my truck: 1951 Ford F2
As for intake though I've always prefered a aluminum one. Just dresses up the motor a little more. Are you tearing into the motor if so I recomend a 4 inch crank conversion. Just food for thought
I would prefer it if it was polished...but I won't polish this one, too "rough". If I do, I'll send it out to have it polished, don't have the gear anymore. I have another block, that I hope to slowly build over time - nice heads, etc. Probably still won't "merc" it, though - too much money for the driving I do. And my truck is pretty much maxed out at 45-50 anyway, with the gearing, etc. And I don't intend to "rod" it at all...I'm an original-type guy. Here's a pic of my Fenton, though, if I ever decide to build something else...
R
__________________
you just need to sell me the fenton roger !! hey now whats with the 48-60 guys remark ? i resemble that ya know !LOL!! well thanx to your oil pan discussion i know for sure i gotz the right pan on my 53 . roger idont know if ya caught my reply but i got a cast intake like your aluminum one without all the bolt holes my ford has for mounting , and roos and a couple of others said it was a merc , or possibly a lincoln intake . has a choke on it , had a stromberg on it thats sitting out in the black hole somewhere , and a rochester will bolt on it . i was gonna have it blasted or tanked to get rid of the rust and crud and drill it so i could use it .
__________________
thats because were all opinionated bullcrap artists looking for somewhere to espout our views and show the world how much we { dont } know especially to newcomers. were on a mission to impress you and make you beleive we are all knowing !
I've thought about selling the Fenton - doubt I'll ever use it, at least not on my truck, but it's one of those things, you will miss it when it's gone!
On the cast intake - are you saying it takes a 4-bolt carb? And as per my discussion - before you drill it, make sure your BLOCK has the "extra" holes. One of my blocks has 14 and the other has 20. You can see the differences in a page I threw together by clicking:
As for the 48-60 remark, I think he's referring to the fact, that most of "us" take our flathead questions to the 48-60 forum, instead of here. That's most of the reason it can be so dead in here. I know I'm usually guilty of that. But, I appreciate the time people take to look here, so I will continue to use it. Lord knows I need to learn a LOT about flatheads!!!
R
__________________
R
Yep, you nailed it. or atleast i'll go with that lol And thank you
__________________ only the finest junk around
2000 Ford F150 Supercab
1946 and 1947 Mercury 1/2ton
1949 Mercury M47
1951 Mercury M-6
1952 F-1
1953 F250
1956 Ford F100
1957 F250
1964 Mercury M100
1967 & 69 F100
4 old Internationals/ Dodges (Hey, Nobody's perfect)
yeah the intake takes a 4 bolt carb roger . and i compared it to an extra intake and the one on the truck and its got lots "o" holes in it , so it'll need to be drilled . i was only making that remark for fun 'bout the 48-60 forum guys too , so no one take it seriously now . im as guilty as everyone else . ask there first as thats where every one seems to be most of the time . and as far as missing things when you get rid of 'em , well , i gave away to my cousin an extra throttle linkage for a 54-56 , and in order to facilitate a rochester when i swap intakes geuss what i need .... yep that linkage as it hooks up on the left , not the right like the 94 on there now . always am i shooting myself in the foot like that !!!!!
__________________
I have had nothing but problems with that big clean out plate leaking oil. I have never been able to get it sealed worth a darn.
Quote:
Originally Posted by rcav8or
I have the truck pan, with the big cleanout that came with my truck (notice I said with and not ON!). The pan had been off forever, full of rusty bolts. This one (I just looked, and took some pics, they'll be up in a few minutes) on it is the car, with the small plug, and hump in the center...
Pics in a minute...
R
__________________ Rod 51 F1 Truck Flathead 6 S-10 5-Speed "Keep on Truckin"
Rod - what was the biggest problem with getting it sealed?
R
__________________
When I first got the truck I dropped that pan inspection cover to look at the pump screen. When I put it back I used the cork type gasket material on it. I didn't use any sealer on it just soaked the gasket material in water good like they recommend. It has leaked ever sense, I have checked the nut tightness several times. I didn't (haven't) checked but if those plate mounting studs/screws are tapped and screw into the pan I suspect that is where they are leaking. The stud/screws always have oil on them.
R
ya know thats the most amazing thing for my old girl is that it doesnt leak { save for anti freeze due to new radiator issues } a drop except for that darn cover even after sitting a quarter of a century . my grand father used to tell me how at the race track if the notorious leaky rear seal would rear ir's ugly head he'd take it apart right there and cut his belt up and make a new seal to get through the night . i took when listening to him that they all liked to leak out the rear seals , then after hanging around here i find it seems to be that cleanout more often than not . just the early ones with the seal issue ????? if you ever decide to sell that intake roger let me know so i can try and hustle some cash up for some odd reason i really want a dual carb intake .
__________________
i just picked up a vintage polished aluminum edelbrock super dual
I like the super dual, if that's the one you can use your stock genny bracket with. I have the Fenton dual, with the angled genny bracket, but I think it requires an "el" so that you can hook the water outlet up.
R
__________________
What year is your flathead? That looks like one off a very early one....
R
__________________
