Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 03-25-2008, 04:58 PM
jerrytown2001's Avatar
jerrytown2001 jerrytown2001 is offline
Garage is empty, add now
jerrytown2001 is starting off with a positive reputation.
caustic instead of lye?
can liquid caustic be used instead of lye in making biodiesel or wvo?
  #2 (permalink)
Old 03-25-2008, 05:31 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
If you mean Caustic Soda that is the same thing as Lye.
They are both Sodium Hydroxide (NaOH)
If you are getting liquid caustic soda (a NaOH water solution) use it in the titration step.
You should be able to find the percentage of NaOH on the label somewhere then dilute it to .1%.
If there are other chemicals present in the solution I would not use your liquid caustic soda.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #3 (permalink)
Old 03-25-2008, 05:44 PM
we use 50% caustic soda where i work. so, i should just add water to bring it to .1%??
  #4 (permalink)
Old 03-26-2008, 08:12 AM
Phydeaux88's Avatar
Yup
50% = 500mg/ml of solution.
to make .1% add 2ml of your caustic soda solution to 1 L water
__________________
  #5 (permalink)
Old 03-26-2008, 09:49 AM
well the lye is going to be pretty cheap, but the mehtanol is kind of pricey. is there any way to reclaim it.
  #6 (permalink)
Old 03-26-2008, 10:14 AM
Phydeaux88's Avatar
you can recover unreacted methanol from both the glycerin and BD products of the reaction. In fact it is recommended that you do so as it makes cleaning the BD easier and cheaper plus the methanol can be reused.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
