Go Back   Ford Truck Enthusiasts Forums > Misc. > Air Intakes, Air Filters & Ram Air
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-25-2008, 02:53 PM
79f100six 79f100six is offline
1978 Ford F-250
79f100six is starting off with a positive reputation.
Foam Prefilter for my truck
I have been watching some tv and seen some of the mud runner trucks that are carburated and they have a foam filter that goes around the regular air filter. I tried looking on the internet and couldnt find anything i was wondering if anyone knew what they are called or where you can buy them. My truck is a 78 with a 400.
__________________
78 f250, 400 motor, edelbrock 600cfm, performer intake, my mud truck
78 f150, 2wd, 400 motor
78 f150, 2wd, 400 motor, custom spray paint camoflauge paint job
79 f100, 2wd, straight six, 3 on the tree
  #2 (permalink)
Old 03-27-2008, 11:09 AM
kens64 kens64 is offline
Garage is empty, add now
kens64 is starting off with a positive reputation.
Summitracing has them. K&N sells them also. I used to run some of that eggcrate foam during the dusty season and it worked well. Cheap and easy to get.
__________________
1964 F100- Gonna see boost
1998.5 Ford Contour- Many mods
http://img.photobucket.com/albums/08...andcar-1-1.jpg
JOIN THE NEW MEXICO CHAPTER HERE
  #3 (permalink)
Old 04-07-2008, 05:24 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to all
K&N makes two kinds of pre-filters. Airforce 1 which is a red open cell foam similar to what Truflow uses as a primary filter and then they have a pre-screen which is pretty much pantyhose that you slip of the filter.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #4 (permalink)
Old 04-08-2008, 01:01 AM
1978 Ford F-250
I looked at summit and i was looking at the k&n foam filter and that pantyhose slip on thing. I was thinking since i have a 4 inch paper filter right now i was going to get the summit 6 inch cotton filter which looks like a k&n just cheaper then get the foam and pantyhose filter things and put both on and the extra 2 inches would make up for restriction even though the foam filter and pantyhose thing only restrict airflow about 2% each, and so when i go mudding i wont have to really worry about getting water or mud clogging up the filter.
__________________
  #5 (permalink)
Old 04-08-2008, 11:29 AM
ReAX's Avatar
2002 Ford F-250
The pantyhose is more for dusty conditions and does it's best work while touching the cotton gauze filters because of the tiny amount of oil it steals. The oil on the pantyhose acts like the filter. The open cell foam is more for the mud environment, it catches and slows larger particles. If you want to try both, I wouldn't stop you, but the open cell is more for your application.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
