Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered Bonus Built, Classic and Box Style Ford Trucks
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-25-2008, 11:35 AM
rcav8or's Avatar
If you use it, SUPPORT IT
rcav8or is starting off with a positive reputation.
Aluminum manifold...painted or not painted?
Quick question for our Canadian friends....I have a Canadian aluminum single carb flathead V8 manifold I am seriously thinking about putting on the truck. Do any of you know if they were originally painted on the motor, or left unpainted? I know what looks good NOW, polished, etc, but want to keep it pretty much stock, and undecided whether to paint or not.
Thanks!
R
__________________
Roger Phillips
Oxford, IN
Be an FTE supporter! Best $20 I EVER spent!!
Click the link for pictures of my truck:
1951 Ford F2
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-25-2008, 11:51 AM
kooper909's Avatar
kooper909 is starting off with a positive reputation.
Stock or not, polished aluminum is period correct, and would look real cool on a flatty. My two cents.
__________________
1960 Ford F-100. '57 292, 3 speed. Mild traditional custom daily driver with red scallops and wide whites.
  #3 (permalink)
Old 03-25-2008, 12:07 PM
cool 48's Avatar
cool 48 is starting off with a positive reputation.
Once it is polished ,I have had real good luck powder coating stuff with a clear powder coat. I have polished lowers fork sliders on bikes, then had a clear powder coat put on. It really preserves the finish ,and loooow maintenance.
__________________
"My pappy said , you gonna send me to the Lord,if ya don't stop driving that ...HOT...... ROD...... FORD!!...
  #4 (permalink)
Old 03-25-2008, 12:25 PM
52merc's Avatar
52merc is starting off with a positive reputation.
The aluminum intake on my 52 mercury was not painted. FWIW neither was the aluminum timing cover.
  #5 (permalink)
Old 03-25-2008, 12:33 PM
rcav8or's Avatar
Quote:
Thanks to all...especially 52merc...polishing is not an option, because I would never know when to stop! Plus, I don't have the aluminum timing cover - they get a pretty penny for those, I've looked....would LIKE to have one, just can't justify the $$'s for a "purty".
As an aside, I am sure glad I took the manifold off!!! There's a cotton towel, stretched across the galley. Apparently, when it was rebuilt, someone put it there, to keep any extra dust, parts, etc out, then put the manifold on without removing the rag!! It only has about an hour or two run time on a dolly, since rebuild, but I am sure glad I didn't try to take it up to speed in the truck! The rag cleared the lifters, etc, so didn't get chewed up (meaning tear-down!), but sure glad I caught it....
Geez!!!!
R
__________________
Roger Phillips
Oxford, IN
1951 Ford F2
  #6 (permalink)
Old 03-25-2008, 12:39 PM
imlowr2's Avatar
imlowr2 is gaining momentum as a positive member of FTE.
Hey, maybe the guy figured "you never know when you might need a rag handy".
__________________
If your not going to do it right the first time, don't do it at all.
  #7 (permalink)
Old 03-25-2008, 12:47 PM
rcav8or's Avatar
Quote:
It has me a little scared - bought this motor already rebuilt and together. The galley is nice an clean, everything so far "looks" rebuilt, but hopefully it's just a fluke, and not a sign of the rebuilders work. It's possible the rebuilder "short-blocked" it, and the previous owner put the manifold on, without looking. Guess I'll run with it, I REALLY don't want to tear the engine down.
R
__________________
Roger Phillips
Oxford, IN
1951 Ford F2
  #8 (permalink)
Old 03-25-2008, 01:12 PM
ontariowestcoast is starting off with a positive reputation.
The answer is not painted. If a truck came with the aluminum manifold it wasn't painted. And they look better too.
  #9 (permalink)
Old 03-25-2008, 01:34 PM
rcav8or's Avatar
This just ain't my day!!! I just found out, my block won't "support" an aluminum manifold! My OLD block would. There's a bunch of mounting holes, that just aren't there, for the aluminum one. They are bosses on the stock manifold, and the holes where those bosses are, aren't in the block, but the aluminum manifold has mounting holes instead of bosses. So, I'm stuck with the stock manifold, at least until I decide to rebuild my original block. My dual-carb polished Fenton won't work on this block either, same reason. Drats!!!!!!!
But STILL glad I took it off, and found the rag. I looked all over the rag for a Ford Part Number, but there isn't one.
R
__________________
Roger Phillips
Oxford, IN
1951 Ford F2
  #10 (permalink)
Old 03-25-2008, 02:11 PM
ALBUQ F-1's Avatar
ALBUQ F-1 is gaining momentum as a positive member of FTE.
Roger, can you explain the difference between the two blocks? I forget, is the new one a 59-series? I didn't think so. Most manifolds have "extra" holes in them, but I've never heard of the blocks not having matching holes. Gotta pic? (I'm sweating, because I have a Canadian manifold sitting in the garage, waiting for some spare time!)
If it is a 59 series block, I have an extra aluminum manifold.
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree
MSD dizzy, 2110 Holley, Red's Headers
  #11 (permalink)
Old 03-25-2008, 02:24 PM
rcav8or's Avatar
Ross, I'll take some of both blocks. I was surprised, too, that the holes weren't there. The new one is a '51 car motor, the old one was in the truck when I got it, but had 8ba heads on it. It wasn't original, and had been rebuilt at one time - .040 over pistons in it. Didn't want to build it at the time, that's why I bought the new "rebuilt" for $1200. I couldn't do my engine for that.
Didn't the 59 have the water intake in the middle of the head? I also know you can use 8ba heads on a 59, or vice-versa if you plug a hole...wish I knew more about these engines!
R
__________________
Roger Phillips
Oxford, IN
1951 Ford F2
  #12 (permalink)
Old 03-25-2008, 02:29 PM
ALBUQ F-1's Avatar
Does your old truck motor manifold bolt up to the new engine's block? Gotta pic of the new alum. manifold?
__________________
Ross
  #13 (permalink)
Old 03-25-2008, 02:33 PM
bobbytnm's Avatar
Roast em' if you got 'em
bobbytnm is gaining momentum as a positive member of FTE.bobbytnm is gaining momentum as a positive member of FTE.
Roger,
Sorry to hear about you not being able to run the aluminum intake. Thats a lucky break on finding the rag though, that could have made for a real bad day. Maybe it was a factory option, you know, a bonus top end filtration system.
Bobby
__________________
...Someday our foes may win...
...but NOT today!!
1949 F1, 500ci Caddy
1959 Dodge D100
1965 Falcon
1994 Harley Road King
  #14 (permalink)
Old 03-25-2008, 02:42 PM
rcav8or's Avatar
Bobby - I looked really hard for a part number on the rag...not there...
I have seen lot's of "old-timer" tricks on the forums, was really hoping no one said "oh yeah, old timers did that to slow the oil flow through the engine" or something like that...
Ross - working on the pictures now...
R
__________________
Roger Phillips
Oxford, IN
1951 Ford F2
  #15 (permalink)
Old 03-25-2008, 02:43 PM
bobbytnm's Avatar
Roger,
It could be worse, we had one gentlemen (who shall remain nameless) find a mouses nest inside his engine. I don't think it had a factory part # either.....
Bobby
__________________
...but NOT today!!
1959 Dodge D100
1965 Falcon
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
