Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-25-2008, 12:48 AM
projectbad78's Avatar
projectbad78 is starting off with a positive reputation.
descreen and gut maf
has anyone done this with or without problems?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-25-2008, 08:49 AM
BrianA's Avatar
BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.
Borrowing a quote from Napoleon Dynamite:
"I don't understand a word you just said."
What is descreening and gutting the maf ???
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
Alabama Chapter Leader
  #3 (permalink)
Old 03-25-2008, 09:08 AM
tomw is starting off with a positive reputation.
What is proposed is to remove all the internal parts of the MAF. Thus making air flow better, but making the engine run at limp-home settings, with poor gas mileage, with poor performance, and with excessive emissions.
Bad idea, IMO.
If you want more MAF air-flow, get a bigger MAF, such as one from a 302, as a guess.
The MAF tells the computer how much air is coming into the engine. If the computer does not know, it has to take a guess so you won't be stranded if it fails. A guess is worse than having the more correct information from the sensor, as it will be most likely wrong. Either too rich or too lean. Take your pick.
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #4 (permalink)
Old 03-25-2008, 02:18 PM
BrianA's Avatar
Oh I know what the MAF sensor does and that is why I couldn't undertand what was being asked.
Rip the guts out? I can't imagine doing that. The engine would still run, but running in "best guess mode".
Apparently some folks have done it, or might, or wonder... I dunno???
As a less involved option, why not just unplug the MAF sensor?
__________________
Brian A
  #5 (permalink)
Old 03-25-2008, 03:09 PM
Brian, this is only a guess on my part. I 'assumed' that he was yakking about getting better airflow with all that excess 'stuff' removed... Maybe he should look at the older foreign models that had a flap that was moved by air flow, and in turn moved the variable resistor... Get that dang flap out of the way, and we'll let in LOTS more air... Wonder why it runs so bad???
tom
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
