Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-24-2008, 09:55 PM
danike is starting off with a positive reputation.
91 Ranger 4.0 lacks power
4.0 engine that was running fine but once in a while would miss on start up for 10 to 20 seconds. One day it ran bad for 2.5 miles then ran fine and that became the norm for a month until now it runs bad all the time. Seems like it is lacking power or out of time. Checked the wires and plugs. Spark jumping out of towers to wires. Had ignition module tested at Autozone OK. Codes 21 and 24 came up when problem is present, replaced the coolant temp. sensor and air temp. sensor no change. Tried a crank position sensor. Have 4.6 volts going to the coolant and air temp. sensor. My book shows alternate meanings for the code 21 and 24 such as crank position circuit and primary circuit in coil. Any ideas or solutions?
__________________
2002 F-150 Screw 4x4 5.4 FX4
BFG All Terrains
Ford Splash Guards
Ford Vinyl Floor Mats
Ventshade Bug Deflector II
Lumi Logo Emblem In Grille
K&N Air Filter
Rancho Steering Stabilizer
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-24-2008, 10:25 PM
mrshorty is starting off with a positive reputation.
Were the 21/24 KOEO codes? A common cause of KOEO 21/24 (especially together) is performing the test on a cold engine. The computer expects to see the temperature sensors above a certain threshold temperature.
What does fuel pressure look like?
__________________
'87 Bronco II XLT 4x4 & '92 Explorer XLT 4x4 & '98 Chev Suburban K1500 SLT 4x4
  #3 (permalink)
Old 03-25-2008, 05:59 PM
Fuel pressure was 32 or 38 psi. The codes did go away when the engine was warmed up and running properly. Don't remember if i check the codes warm and running bad.
__________________
BFG All Terrains
Ford Splash Guards
K&N Air Filter
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
