Manually unlocking door or someway to pop hood from outside - Ford Truck Enthusiasts Forums
Old 03-24-2008, 08:39 PM
kstng50 kstng50 is offline
kstng50 is starting off with a positive reputation.
I have an 04 explorer XLT. The alternator went on the car so I took it off and got a new one. The problem is the one they gave me was the wrong one. They had to order this one and it would be a few days. I didnt hook the battery or anything back up while waiting for the new one. Now I can not get into my car because the key does not work in the door for some reason. I guess it is an electrical lock and not manual? I owned the car since new so I know the lock is the original in the door. Is there anyway to get in my car or to pop the hood from outside of th car? It looks like the hood release is going by the front left wheel well. If i take that off will I be able to pop the hood by yanking on it? Any help would be greatly appreciated. This is driving me nuts trying to get into it.
Old 03-24-2008, 09:05 PM
99f350sd 99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
Welome to the site! Too bad you had to have this happen for the visit..
Don't pull the wheel well out you won't have any luck in there. You may be able to get at the latch from the front..I'm gonna check mine to see.
Dick
Old 03-24-2008, 09:25 PM
Hopefully i can get at the latch from the front. I couldnt really loock at it to much because it was dark out. I tried to slim jim the door but was unsuccesful. Is there a special spot to use a slim jim on this year car? Or is it even possible to use a slim jim?
Old 03-24-2008, 09:31 PM
Ok the key isn't electric. Its manual. Put the key in and pull out a little and wiggle and try to get it to work...We never used ours and it took 10 secs or so...
Dick
Old 03-24-2008, 09:33 PM
rrgone rrgone is offline
rrgone is starting off with a positive reputation.
Jeez I don't think I've ever opened mine by just turning the key in the lock. That's suppose to work of course... I'm gonna have to go try it to make sure...
Edit: Well mine works like a champ both locking and unlocking with key in the lock. Sorry to say but maybe something came unlinked in your door. I'll bet a good locksmith will know how to jimmy it open but I don't. Good luck!
Old 03-25-2008, 06:38 AM
Something is definetly unhooked on my truck. I jjst tried it this morning on my other explorer and it unlocked fine. The one that is stuck moves the same as the other truck but there is just no resistence when turning it.
Old 03-25-2008, 08:43 AM
Bummer ,if it turns and nothing happens then how about you see if you can reach under the truck to get at the pos battery wire. You could rig up a battery charger or some wires to attach to it and neg to ground then you could get in.
Old 03-25-2008, 08:53 AM
It might be a little far but that might be a good option if somehow I can reach the batter cable. When all this happened it was getting dark out so it was tough to see. Hopefulyl when I get home from work I can find someway to get the hood opened. Or atleast pop the door lock. Has anyone ever been succesful at slim jimming the door on this year?
Old 03-25-2008, 09:02 AM
Backin72 Backin72 is offline
Backin72 is starting off with a positive reputation.
Stupid question but.......have you tried the key in all the doors?
Old 03-25-2008, 09:04 AM
MisterCMK's Avatar
MisterCMK MisterCMK is offline
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
Take a look underneath the truck and you should be able to find a way to release the hood from below. It will probably be a pain in the butt though
Old 03-25-2008, 09:11 AM
The thing that sucks is that there is only one key lock on the entire car.
Old 03-25-2008, 10:48 AM
MisterCMK's Avatar
Avid Winter Hater
The rear hatch should have a key lock
Old 03-25-2008, 11:08 AM
Nah there wasnt one on the rear hatch I thought the same thing. I looked all over it. The good news is it is open now. The bad news is it cost $75. I didnt feel like messing with it and getting all angry so I just payed a lock smith to open it. Now I can throw the alternator in and be done with it when I get home.
Old 03-25-2008, 11:02 PM
SPELLY F150 SPELLY F150 is offline
SPELLY F150 is starting off with a positive reputation.
Did you ever think to call the local PD and see if they could give it a shot opening the door. I know we don't even carry slim jims in our cruisers any more. We now have a tool called the BIG EASY. It kinda looks like brake line, but you pry the top of the door open with a plastic wedge and slide the pole into the car and you can press the unlock buttor, or in your case you can hook onto the door latch handle and pull to open. This tool take a 1/4 the time as a slim jim. Reguardless, Glad to hear you got the door open.
Old 01-27-2011, 10:11 AM
espygarcia espygarcia is offline
espygarcia is starting off with a positive reputation.
i need help please!!!
i have a 99mustang, that has a different alarm system. last night i left the lights on so my battery died, this morning i tried unlocking the car didnt work the key wont unlock it either i dont know why i think its because a different aarm system was put in. i need to mnow how to open the hood from the outside so that i can somehow charge the battery with jumper cables or something. i dont know anyhting about cars please help
E99 F350 Brake Hose Failure jhl3 1999 - 2003 7.3L Power Stroke Diesel 4 11-24-2014 12:51 AM
96 f150 door passenger door wont open from inside or outsidr hoopdieking 1987 - 1996 F150 & Larger F-Series Trucks 0 03-21-2014 05:58 PM
94 E-150 driver-door lock and latch problem Mocha Joe 1968-2013 Full Size Vans 3 06-26-2013 08:28 PM
79 f250 hood release mechanism 4rdnut 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-13-2011 04:53 PM
Locking Hood Latch for 1973 Ford Camper Special F250 questions??? robertbenita 1973 - 1979 F-100 & Larger F-Series Trucks 14 10-16-2010 06:34 PM
Tags
2005, atuck, cadillac, car, door, expedition, ford, hood, jim, loock, open, pop, popping, slim, truck, unlock, unlocking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
