Quote:
Originally Posted by kynnhoj
Could be your fuel filler neck decayed and cracked. There is also a vent hose that runs right next to same.
Could also be the fuel rail, o-rings at each injector, pressure regulator, etc.. You need to take the doghouse off to look at that. Fumes are flammable, be careful!
John
Good call, I'll try driving with the doghouse removed til I can smell fuel then pull over and see if I can track it down. Thanks.
