Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 03-24-2008, 06:12 PM
berry1234's Avatar
berry1234 berry1234 is offline
Garage is empty, add now
berry1234 is gaining momentum as a positive member of FTE.
Strange noise while turning....
Last night while left turning onto my street I heard a 'hoooooot' noise coming from the back end. Today while turning right onto a street I heard the 'owl' sound again. Happens at the time I am straightening out. I will mess around and see how I can exactly duplicate before I take it in. Wheel bearings? Rear end? Are there clutches in our rear ends?
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #2 (permalink)
Old 03-24-2008, 06:50 PM
Newton007's Avatar
Newton007 Newton007 is offline
Newton007 is starting off with a positive reputation.
"Are their clutches in our rear ends?" Aummmm, won't touch that question.
As far as the noise, I don't know, might have something to do with the braking system or the traction control as there is no posi track third member. Hope it is not a wheel bearing as they normally go a long long time. There have been some reports on this site about clunking noises on backing up, but I have never had this problem. (yet) I would just guess brake noises. Turning right or left might make a difference in the noise. I would try that. The way the traction control works using the brakes may have something to do with it. It may be acting up when it should not. Don't know.
  #3 (permalink)
Old 04-10-2008, 05:10 PM
expy37at expy37at is offline
expy37at is starting off with a positive reputation.
My 2001 had a similar sound and after a year and a lot of towing the diff input seal began leaking.
Turned out the preload on the input bearings was loose.
Fixed it myself.
Tags
backend, differential, excursion, f150, ford, lincoln, making, navigator, noise, noises, rear, sound, strange, truck, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
