'87 F-150 GVW & Curb Weight (UPDATE!) - Ford Truck Enthusiasts Forums
Old 03-24-2008, 03:28 PM
jnewkirk77's Avatar
jnewkirk77 jnewkirk77 is offline
jnewkirk77 is starting off with a positive reputation.
OK, guys, I now know the curb weight of Big Red with about 8 gallons of gas in one tank, the other one empty (it's dead anyway).
It's 3900 pounds, squarely on the nose.
I say that with confidence, since I just took my three-year-old son and 18-month-old daughter to the doctor, where they weighed in at 45 and 25 pounds, respectively, and I pegged the scale at 190 at my last doctor's visit, and that matters because the landfill scale showed the truck's unloaded weight (including the three of us) at 4160 lbs. Subtract us, you get the 3900.
So, with Big Red's meager 4900# GVWR, I don't have a hefty payload. But in my research on the matter, it turns out that neither did a lot of other half-ton trucks up until the first F-150, Chevy "Big 10" and Dodge D-150 came out in the mid-'70s to get around the looming emissions standards, which didn't affect 6000+ GVWR trucks until '79 or later. That isn't to say people weren't loading above and beyond the GVWR! (Trust me on that one ... from experience!)
I will say that we had a nice, smooth, steady ride across town to the landfill, what with all the crap I was taking to dispose of from the garage clean out & renovation process. The rear end was barely lower than normal, so I must have some pretty decent springs under there.
Old 03-24-2008, 04:32 PM
chewie1014's Avatar
chewie1014 chewie1014 is offline
chewie1014 is starting off with a positive reputation.
So...GVWR of 4900# minus the 3900# curb weight equals 1000#. Sounds like a half-ton to me.
Old 03-24-2008, 05:59 PM
jnewkirk77's Avatar
Yep. That's what it is, all right!
To be honest, I'm not real worried about overloading the truck, as I so seldom do the really serious hauling like I did today. I guess I just need to clean out the garage more than once every four years ...
Old 03-24-2008, 08:37 PM
fordman1090 fordman1090 is offline
fordman1090 is starting off with a positive reputation.
my 93 extended cab says 6050lbs. I think the truck weights about 4500lbs at most, so i have 1550lbs payload. Does that sound right to anyone?
Old 03-25-2008, 01:46 AM
jnewkirk77's Avatar
That sounds about right.
Old 03-25-2008, 10:48 AM
chewie1014's Avatar
Quote:
You'd be surprised how much weight the extended cab adds to the truck. I too have a 93 extended cab with a GVWR of 6050#. And like jnewkirk have recently been to the scales to drop a load. The truck with me in it (170#), a few tools (30#), and a fiberglass top (200#) was 5160 lbs. So with one tank full it's sitting at 4750# curb weight. Pull that from the 6050# GVWR and your looking at 1300#. I've got the 5.0 V8 with E4OD 2WD set up.
So, you're pretty close.
Old 03-25-2008, 11:33 AM
Ya, it all mathematically makes sense. But the 4900# that jnewkik's trucks gvwr is then the supercab jumps to 6050#. It suck a big jump that i would expect.
I'v never had it on a scale so i have no idea what its weight is. With tool box and headache and the super bumper, im sure my truck weights a ton more then the 4500# i mentioned earlier, But the numbers i figured were for a stock truck with out all the stuff.
And it always amazes me how quickly things add up and your payload is full. haha
Old 03-25-2008, 01:53 PM
chewie1014's Avatar
When you break it down, it really isn't that big of a jump. Payload is completely different than towing ability. The curb weight jumps by 1150# on a Supercab, but the majority of that is made up in the extra weight added to the truck by the extension - which is roughly 800-900 lbs. So, the payload is really only increased by roughly 200-300# depending on the truck. Given his truck and my truck have the exact same setup regarding drivetrain and engine, I'm not entirely sure why I get an extra 300# payload just because I have the supercab. I'm sure there's a logical reason to it, I've just never looked into it.
Anyone got any ideas?
Old 03-25-2008, 02:15 PM
Well with a supercab you do have room for upto 3 more small people, and the longer frame distributes the weight differently. That could be some of the reasons for the higher payload.
Just a thought,
Any Other Ideas
Florida HOA does not like my custom F600 dbreienrk1 General Automotive Discussion 21 02-10-2016 03:09 PM
Actual payload capacity numbers myredracer 1999 to 2016 Super Duty 17 06-11-2015 05:12 AM
How do I weigh the front and rear axles? luisp1966 Excursion - King of SUVs 20 05-10-2012 11:45 PM
Effect of Weight Distributing Hitch of Tongue Weight? flitchplate Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 11 04-25-2005 09:26 PM
2005 GVWR and payload, a comparison V10man 1999 to 2016 Super Duty 1 07-28-2004 10:22 AM
Tags
1987, 2010, 4x4, 87, 93, curb, d150, dodge, f150, ford, gross, gvw, payload, scale, truck, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
