Trailer hitches and wheel interchange questions...
Well now I need to get a hitch for my aerostar. In the manual it says I have about a 4000 lb towing capacity, so I'd like to get a hitch that can handle that. Is there any particular brand/type that's best? Any particular place offers the best prices? Also I have a bike rack that attaches to one of the smaller trailer hitches (on my Honda civic), I think it's a 1.5 inch x 1.5 inch square? Is it possible to have a trailer hitch that's this smaller size and yet it still has a 4000 lb towing capacity? I'd like to be able to use my existing bike rack easily without using adapters etc and would also like to tow small trailers without swapping out the bigger towing ball.
Also, does anyone know if 15" aluminum wheels off of a '92 Ranger will fit my '97 aerostar? Thinking about changing over to 15 inch tires for a wider selection instead of the seemingly outmoded 14 inchers.
Thanks...
Thanks...
Thanks guys. And 96 I don't plan on hauling any 4000lb trailer cross country, but an occasion might crop up from time to time that may require me to tow something close to that over a relatively short distance (no big hills). For instance, I was thinking about getting a car tow dolly and when needed I might transport my Honda (or something similar) once in a while over short/moderate distances. So there will probably be cases here and there where I might actually need that capacity. With that said, is there any particular hitch that would be best? I'm assuming Reese but I see a lot of "valley's" too.
I would go with any good brand of hitch. I believe you can buy converters to go to a smaller hole or ball, that way you could have the class III/IV hitch for the Aero.
As for your question about the Ranger rim, yes it will fit, all Ranger/BII/Explorer/Mazda B series rims are interchangable.
Hitch and spare tire
I have a Hidden Hitch Class II on our '96 extended van. We pull a coleman popup in summer, and occasionally one axle Uhaul trailers, with no problem. If I recall correctly, not ALL aftermarket hitches leave you room for a full size spare, so you might check that out, if you like to carry a full size spare.
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
12-06-2016 04:10 PM
Torklift Sheryl
07-10-2015 12:55 PM
Torklift Sheryl
06-18-2015 09:51 AM
FordmanNJ
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
08-13-2014 11:08 PM
