2000 F150 keyless remote - Ford Truck Enthusiasts Forums
Old 10-15-2001, 09:19 PM
Nortec40 Nortec40 is offline
Nortec40 is starting off with a positive reputation.
Does anyone know how to program a keyless remote for a 2000 f150 I have a new one and need help. Ford Rules!!!!!!!!
Thanks Mike
Old 10-29-2001, 08:40 AM
jetmech jetmech is offline
jetmech is starting off with a positive reputation.
1999 f150 had a heck of a time getting the pattern down to program it. but it did finally work. First of all,you need to have your prevoiusly programed FOB handy and also the one you are going to program handy. insert the key in to the ignition and turn from off to run "several times" so the dealer said. I think I turned mine atleast a hundered times. anyway, repeat this step until the locks activate, then hit your lock button on your programed FOB, locks will cycle then hit your lock button on your programing FOB, locks should cycle again, and that is it. when locks activate the key needs to stay in run position during procedure. Otherwise, you will have to repeat the pattern again.
good luck,
JETMECH
Old 10-29-2001, 11:33 AM
baumfr baumfr is offline
baumfr is starting off with a positive reputation.
I've read that early 2001 Supercrew XLTs did not come equipped with standard remote access (option only). I've also heard tale of salesmen telling cutomers (knowingly or unknowingly) that the fobs were apparently lost but they could get new fobs and program them. Be careful.
Old 10-29-2001, 09:39 PM
ange ange is offline
ange is starting off with a positive reputation.
remote start with key-less entry question fordguy2236 1997 - 2003 F150 2 07-13-2013 10:49 PM
Keyless Entry??????????? selmarescue 2004 - 2008 F150 3 12-03-2006 02:16 PM
adding keyless entry?? bkaeding 1997 - 2003 F150 3 11-02-2003 03:54 PM
Remote Keyless Entry aldridgec 1997 - 2003 F150 2 01-26-2003 09:54 AM
battery for keyless remote texaslj 1997 - 2003 F150 3 12-14-2002 08:02 PM
Tags
2000, f150, programming, remote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
